Saw wont run more than 10 seconds
countryhog
BTDT
6:03 PM
NW Arkansas
Poulan 2000. Starts on choke, runs about 10 seconds when choke turned off. Then dies. Just cleaned carb because of same sympton. replaced fuel line cause i thought it might be sucking the line closed; no change. I intend to do a pressure/ vacuum test but until i do wondering if anyones got any clues.
TIA
pbillyi69
4:03 PM
USA
clogged filter, tank vent, stiff diaphragm and not pumping or impulse line kinked
pbillyi69
4:03 PM
USA
have you tried turning the screws in to the seat and starting over on tune from base setting?
pbillyi69
4:03 PM
USA
can you get it to run with the throttle
countryhog
BTDT
6:03 PM
NW Arkansas
Readjusted both thr H and L screws. Tank is half full. Throttle works the first 10 seconds only.
Forgot to thank you for assistance. Thanks
pbillyi69
4:03 PM
USA
try filling it all the way up to eliminate a possible pin hole or tear in th fuel line. i see that you replaced it already. sometimes they get tiny holes. i dont think thats it but cant hurt. check for proper needle adjustment. what carb does it use? is there a pump bulb? if so make sure the hoses are hooked up right. i got one that would only run for a shot time and the lines were backwards on the primer bulb
pbillyi69
4:03 PM
USA
oh and you are welcome. these are just things that come off the top of my head realatively quick check items
Wonkydonkey
Plastic member
12:03 AM
Sussex, UK.
It does sound like fuel starvation.
As most peeps here know, the choke reduces air flow and thus the crankcase is rich in fuel. This gives the engine a chance to pop and then it can pulse fuel and air at the correct ratio.
If it’s getting fuel to the carb with the choke on and then running for 10seconds once the choke is off . It could be little or no impulse or partially blocked fuel filter ( is the impluse line split or perished or blocked)
Or it could be a pin hole in the carb diaphragm and sucking air,. Maybe a partially blocked fuel strainer in the carb.
If that’s all ok? I”d be looking at a possible sparking problem, ie when the saw starts the vibration interferes and the spark is reduced or not sufficient.
Wonkydonkey
Plastic member
12:03 AM
Sussex, UK.
just to clarify, when I say fuel starvation, I do mean not enough fuel and air mixed into it.
I'd be looking for air getting in to the fuel ie pin holes. A Kink in the fuel line or a fuel line that has gone soft and collapses when fuel is drawn through it quickly
Tomos770
1:03 AM
Slovenija
Crank seals....its not building pressure inside the fuel tank!
Try to prime it in that 10s airframe....if it runs while priming.....crank seals!
countryhog
BTDT
6:03 PM
NW Arkansas
New filter
Vent is in the cap- will check it
Diaphragm doesnt feel stiff-will check it
Impulse is through the carb
Thanks for help
pbillyi69
4:03 PM
USA
i would check the impulse passage make sure its clear.
bogieboy
7:03 PM
Kingsport, TN
Pull the carb, then pull the reed block under it, make sure you dont have junk in the reeds... my 1800 had that issue... if the reeds get stuck, it doesnt get a good implulse to the carb, and doesnt pump fuel
Brad Button
4:03 PM
Angels Camp,Ca.
You said you took the carb apart and cleaned it, did you put a new carb kit in it? Did you set the metering lever height?
countryhog
BTDT
6:03 PM
NW Arkansas
Lot of good ideas which i will follow up on.
The kit wasnt new but hadnt been used much after replacing it. Got so many saws that they tend to sit for long periods of time.
Which brings up another question. Why would a rebuilt carb that was shelved need to be cleaned up to make it run? This saw had been previosly rebuilt, including carb, used maybe once and shelved. Hence the current rebuild
