Saw video thread
Deets066
AKA Deetsey
10:24 PM
Little feller might like the 7 tooth better than the 8 I have on it. Or maybe once the new ring seats it'll take off
Seating the ring gains more than one would think. That little 024 super I have really came to life. It’s running an 8 picco sprocket, that’s pretty close to a 3/8-9
10:24 PM
Nice Mason. Tough to get real accurate times with that piece.
572 sounded great and very smooth.
How did they oil the bar? I am sure the 395 was good, but how about the others?
10:24 PM
Yeah wasn’t the piece I’d choose :(. But it’s what I had to use. I stopped when the bottom of the saws hit the ground since I couldn’t cut all the way through easily. They all oiled that bar well and didn’t seem to struggle with it. Especially the 395 obviously... lol
10:24 PM
What's done to the xtorq?
Base gasket delete, lower transfers matched to the base, blended the thick division more where the strato ports split into two on the cylinder, cleaned flash off the piston, little more intake duration, little timing advance, muffler mod, cut the division out of the filter holder, but left the strato intact in the carb and boot. I don’t like them gutted. I also put a older OE flywheel on it too (lighter). Still has limited coil. Lot of little things but nothing major or crazy. Mild build I guess.
10:24 PM
I wouldn't think that's all due to the added compression when they seat. I bet a lot of the charge is lost due to blow-by also
10:24 PM
The modded xtorq in the video picked up quite a bit from a set of new caber rings. It used to be slower than a stock 572xp and have less compression than a stock xtorq. Now it pretty much hangs with the muffler modded 572 and compression is healthier.
10:24 PM
I’m gonna go out on a limb and say half the people on this forum the almost stock OE 50mm 372 would be more than enough saw to do anything they wanted to. It pulled and oiled a 32 with half skip darned good in hardwood for 71cc’s with 5.5hp or something like that. It’s no 395xp, but it’ll do it in a pinch with a sharp chain. Surprised me. You can put on a short bar, fast chain on it and take some names at a gtg too.
David Young
Safety First !!!!!!
10:24 PM
vt
Better late than never. Lol
I didn't realize Jred made a diesel chain saw.
The stock wot rpm was. 10.5k! I will have to tach it.
It’s fun. You push and push it doesn’t change tone. I’ll have to slap a bigger bar on it to test it.
chipper1
10:24 PM
Grand Rapids Mi
And an XT would do them even better and be more forgiving.
This one was second on the same chain.
Plenty of guys say they won't run without an unlimited coil and an hd filter, okay lol.
This one has a base gasket delete and a little larger MM.
10:24 PM
The xtorq can run good for sure. I wouldn’t put a unlimited coil on a xtorq though anyway with the heavier piston and plastic cage bearings.
