- 11:13 AM
- May 30, 2016
- Ct
Love the sound of them twins!! Thanks for sharing.2 man saw...
I'm unsure of the model and the name of the gentleman helping Sheldon with the cut. The chain is 3/4 pitch.
Mark running his Solo Twin...
.. and Dave trying to get a reading with his tachometer.
it already has 5 tanks run though it.Sounded good for an 028. Wait til it has a few more tanks through it. [emoji106]
Definitely looks stout.well guys how did my old saws do in those videos.
A 44 is a good saw but use it all day and then pick up a saw with spring AV you won't want to use it. I'd like to try a 441. That's my personal preference. Speed is only part of the story with actual productivity. Some aren't bothered by the 044/046 anti vibe and that's fine everyone is different.Good thing the 044 wasn't still around!
it will be a few days but i will a video of it noodling.Definitely looks stout.
What are the odds of you noodling that log on video? I'd like to see that 028 in a high torque situation.
a worn out stihl rollomatic laminated bar 18''Looks like it runs well Jake. What B&C you running?
How does it feel when you use it?
My sentiments exactly.I like the rubber AV still, I have a better feel for the saw. Espeacially with a longer bar. Some of the springs are just too soft for me
Only time I like rubber av is to fall trees. It's just what I learned on and is more comfortable. 661 with a 36 felt like a 372 with a 36. A/V limiter all maxed out and the bar not parallel to the powerhead.I like the rubber AV still, I have a better feel for the saw. Espeacially with a longer bar. Some of the springs are just too soft for me
I'm starting to wonder if some saws have a better balanced crank/piston. I ran a 9010 smurf ported that has rubber AV and it didn't seem to bother me. Stihl 024/026 series don't seem to be too bad as well. Does compression affect vibration? Just brainstorming here. I know a 6100 has around 200 factory compression and it's smooth as can be, maybe well balanced rotating assembly with good AV?Some do and some don't.
