WANTED Saw capable of pulling a 24" bar with AUTHORITY
Cut4fun
Redneck Chainsaw Repair
12:39 PM
Ohio
I would not run a 24" even in 325 on a 54cc. JMO
But I have this like new one on the shelf. Pulls 180psi. Green tank and front exit muffler 3450.
Had 3 saws sold but the $$$ never showed. So they are still FS. This is one of them.
p3450xtomanytocountnow 006.JPG p3450xtomanytocountnow 004.JPG p3450xtomanytocountnow 002.JPG
DrewUth
Too weird to live, too rare to die.
12:39 PM
SJ
Yea, 85% of what I cut is oak. If you think the hotter poulan will pull the 24" .325 no problem, that might just be the most economical way to go. So @Cut4fun ....you have a 3.0/3000 crank or parts saw you want to let go of? I need a crank, a top cover and airbox cover, and a handle.
EDIT I just saw your last post, it didn't come up initially for some reason. So that 3450, whats the story on it? You say you wouldn't run a 24" bar? the 3450 is just a 54cc model, right? Or is it 60?
RI Chevy
12:39 PM
earth
I have a nice Stihl 029 that I can strap a 24" bar with 3/8 for you if your interested. I will take some videos if you're interested.
Saw runs strong.
Right at your price range.
DrewUth
12:39 PM
SJ
Saw runs strong.
54cc?
RI Chevy
12:39 PM
earth
Not sure. Stock Stihl 029
Ryan Browne
11:39 AM
Wisconsin
In my experience, an 029 might pull a 24" bar with skip chain, especially in softwood. The word "Authority", however wouldn't be part of the situation. Throw an 039 top end on it, though, and you're getting somewhere...
RI Chevy
12:39 PM
earth
Yup. I hear you. I was planning on doing that if I ever blew up the saw, but it runs to good to mess with it. Not touching anything until I have to. Lol
Saw does have a muffler mod and retune which really woke up the saw.
chainsawman2011
12:39 PM
Michigan
I had a 290 I swapped to 3/8. With a 20" it was very iffy. It would pull it but in red oak you had to baby it
U need to run skip chain and do a muffler mod and remove limiter caps on carb and return carb then it will cut better
RI Chevy
12:39 PM
earth
I did the muffler mod and removed the carb limiters. Really woke up the saw. The skip chain would definitely do the trick.
Thanks for the great info Jim.
sawfun
9:39 AM
Portland Oregon
I have an 044 for a 20" now
Yup, me too. Its fun to run that against my 700 with a 20" bar. Old school torque becomes apparent as does modern saws speed. Both put smiles on every face when cutting firewood. They may be heavier than 50cc saws but are a ton faster. In those bar lengths firewood cuts like butter.
T.Roller
12:39 PM
Southeast, TN
Agreed. 20" with a 8 pin. Pulls great
sawfun
9:39 AM
Portland Oregon
Its also easier on the saw compared to maxing out bar length. Though bending with the shorter bar can be a back killer. I often find my back hurts less with my 372 and 28" lightweight bar than it does with my 346 and 18" bar after a couple hours of cutting.
Ryan Browne
11:39 AM
Wisconsin
I like being over gunned too. 7 pin 3/8" 20" bar on my 460. Although I did recently play with an 8 pin and a 20" bar on my MMWS 660...
DrewUth
12:39 PM
SJ
My dad has a 290, and my Poulan 3000 SMOKES it. Like, I'm standing up having a sip of beer while he's still in the cut. I run 18" on the 3000, but his 290 might have a 20" on it; I'm not positive.
The difference between an 18" and a 20" is negligible to me, I have two 50cc saws, one with each size bar and they run fine- yes, in hardwood too. I recently had two jobs where I was cutting and noodling 36" wood; the 20" saw isn't running right so I did it all with the 3000/18". The saw ran great and never balked at the task, but having to match two cuts up sucks.
RI Chevy
12:39 PM
earth
Stihl 029 is a far better saw and much more reliable.
Jwalker1911
11:39 AM
Nebraska
Shop around,you never what you will find. I just picked up a Jonsered 801 for nothing and dumped the old fuel out,cleaned it up and fueled it and it runs like a champ.
