- 10:05 PM
- Feb 5, 2016
- Here & Now
I’ll grab a picture after I eat of a trick I use to speed a round tooth up when I’m bored and filing chain.
Small file completely under top plate. Basically just beveling the gullet some. I think it smooths the cut some. Maybe very minor speed increase. You don’t wanna go all the way to the original edge you make with the regular file you usually start with or the edge will get fragile. Do you point out to the 5 guys, which chain is the good one, and indicate the bad ones? And tell them why?Next time you guys go to a gtg observe the way people’s saws cut. Out of 5 people guarantee that one will be dull, one will have too agressive rakers to make up for poor filing, two will be average and one will be exceptionally good. Ask the person what they did to make it cut good.
Definitely getting your nickles worth outta that one!!!!
I tell them if it’s dull for sure. One thing I can’t stand is a dull chain.Do you point out to the 5 guys, which chain is the good one, and indicate the bad ones? And tell them why?
It’s durable. Just really depends. Clean wood it lasts. Trash I cut in. Not so much.Purdy, looks kinda like off the roll RS.
How many tanks can you get out of it?
Save Edge Chisel Bit files.If you guys don't mind my asking, what type of files are you using for square chain? I see they make a double bevel and a 3 corner. Any particular positives or negatives of either design? Thanks.
Sent from my Moto E (4) using Tapatalk
Thanks!Save Edge Chisel Bit files.
Sir, I only do work chains primarily. I do have a couple chains that I mess with. But in general, yes. I am not really that adept with all this racey stuff.Jeffy... do you sharpen all your chains the same for all your saws?
