Riveted Husqvarna Tag Question
Chainsaw
4:27 PM
Mid Atlantic USA
I’ve got a couple of Husqvarna chainsaws that have the black engraved tag riveted to the case. I understand how to read the serial number for date of manufacture.
Question is - when I see Sweden at the bottom, is that the country of mfg? I recently saw a 455 and the tag on it said Brazil - which I assume is also country of mfg? OTOH - I’ve looked at a few ‘s’ 400 series at Tractor Supply and there is no riveted serial tag. Where is the serial tag located on these saws?
Thanks!
hacskaroly
2100 Fanclub Member
1:27 PM
Northern Idaho, Ehh
Do you remember which series numbers they were? I have a 435 from TSC and it has a serial tag in the typical spot, I had a 455 from them also, but gave it away so I can't check it, but pretty sure it also had a serial number tag too:
Duce
4:27 PM
Roscommon, MI
Thanks!
Some tags are under top handle on clutch side of saw.
Duane(Pa)
It's the chain...
4:27 PM
Centre County
I tore down a 346 NE one time. There was a plastic decal/sticker under the handle mount on the clutch side that had same data as the riveted tag. I also have Echo saws with and without riveted tag. Those without a tag have info embossed on the case, but not what I would call engraved. Stihl has serial number on cases that can't be seen when assembled.
Coupe
8:27 AM
New Zealand
I think with Husqvarna's there is quite a lot of places in the world where they are assembled.
Foe instance I had a Husky 36 made in usa on the plate and found out from a husky dealer
the smaller Huskies were made by Poulan. I had a mate by a Husqvarna 36 the same as mine
and on the tag on his it had PRC which stands for Peoples Republic China. I have heard various
reasons for this and one is Husqvarna make the parts and send the to assembly countries to
put together and another one is they chase cheaper labour. I think all there bigger saws are
still made in Sweden . Somebody else on the site may be able to add to this and put you
on the right track
Chainsaw
4:27 PM
Mid Atlantic USA
