Riding mower loosing ground
merc_man
merc_man
2:37 PM
southern ontario
I got a riding mower and just looking for ideas to try.
So i think it has bad wire somewhere. With key off i have good ground from battery to engine block.
Turn key to on i loose that ground.
Key in crank i have 12 at starter
Bench test starter and works
Batter has 12.4 volts
Shane¹
2:37 PM
Kentucky
Take a set of jumper cables and go from b- to the engine block somewhere and see if it starts after that and if it does then you know the ground is bad
redneckhillbilly
12:37 PM
NW MT
some of the safety switches could interrupt the ground as well, cycle all the safeties also, maybe have someone sitting on the seat when your testing things
OnlyStihl
12:37 PM
PNW
A battery ground wire is connected to the frame, right? An ohm meter is basically checking the continuity of the ground cable. How does an ignition disconnect a 2AWG wire bolted to the frame?
redneckhillbilly
12:37 PM
NW MT
seat and brake are the main ones, depending on model, some have electric pto switch for the blades. loosing the ground is common when a + wire is damaged and goes to ground
merc_man
merc_man
2:37 PM
southern ontario
I will hopefully get a chance this week to have a look. Had a lot going on this weekend. I was thinking safety switch but i still get the solinoid click with key. I will still check them though to be sure.
