Riding mower loosing ground
merc_man
merc_man
7:10 PM
southern ontario
I got a riding mower and just looking for ideas to try.
So i think it has bad wire somewhere. With key off i have good ground from battery to engine block.
Turn key to on i loose that ground.
Key in crank i have 12 at starter
Bench test starter and works
Batter has 12.4 volts
Shane¹
7:10 PM
Kentucky
Take a set of jumper cables and go from b- to the engine block somewhere and see if it starts after that and if it does then you know the ground is bad
OnlyStihl
5:10 PM
PNW
A battery ground wire is connected to the frame, right? An ohm meter is basically checking the continuity of the ground cable. How does an ignition disconnect a 2AWG wire bolted to the frame?
redneckhillbilly
5:10 PM
NW MT
seat and brake are the main ones, depending on model, some have electric pto switch for the blades. loosing the ground is common when a + wire is damaged and goes to ground
merc_man
merc_man
7:10 PM
southern ontario
I will hopefully get a chance this week to have a look. Had a lot going on this weekend. I was thinking safety switch but i still get the solinoid click with key. I will still check them though to be sure.
merc_man
merc_man
7:10 PM
southern ontario
Ok so i made some progress but still stumped. So i found a loose ground bolt by battery. Got that cleaned and tight.
So now go to start and starter tries. Ausome but shortly after see smoke at starter. So i got continuity from engine block through starter to the starter positive wire up to the solinoid.
Undue battery terminal quickly lol. Seemed to take forever.
merc_man
merc_man
7:10 PM
southern ontario
So i just checked on my good John deere mower and i got continuity from block to starter positive too so that must be normal
