Regular .325 chain on a nk bar?
Farmchuck
5:34 AM
Nepa
Hello all. I have a 550xp, I just recently acquired a new Oregon speed cut 16" .50 nk bar. I have several loops or Stihl .50 .325 16" chains, both chain & bar are 66dl, but I don't believe the Stihl chain is narrow kerf. Will it work on the nk bar or will I have clearance issues?
jake wells
no longer here
4:34 AM
ky
i have ran regular chain on a NK bar why don't you try it out? it worked for me.
concretegrazer
4:34 AM
Mo
It depends on the bar. I've ran rs on a nk bar on my 550 without issue. I think it was @Joe Kidd that said he has seen some issues.
SawTroll
Information collector
11:34 AM
Troms, North Norway
Hmmm...i could be wrong. I know some it works on and others it doesn't. Ask @SawTroll he knows.
As far as I know it normally works on 346-family saws, but basically not on 550-family ones. It may be a matter of production tolerances though, so exceptions doesn't really surprise me.
Since those components aren't designed/meant to work together, it is just a bonus when they do, not a flaw when they don't.
Regardless, it should be possible to make it work on at least most saws where it doesn't work in the first place, by using shims around the bar bolts, next to the bar (making the bar artificially thicker at that point).
Farmchuck
5:34 AM
Nepa
Good idea! I suppose some flat washers would do the trick?
SawTroll
11:34 AM
Troms, North Norway
Something like that - and it may vary if they should be used inside or outside the bar - or both. Many washers likely is thicker than needed though, I'm thinking really thin ones in the first place.
