Reed Valves?
Maine Ruffcut
2:52 PM
Maine
I have a Homelite 1130g with 4 reed valves that are slightly open, would say 1/16. But on my 1150 auto, they are closed. So I don't know if there are any specs that are exceptable. Thanx!
2:52 PM
I would say they should be tight against the cage .I assume they are caged like the 2100 ? I've got the book some place ,I'll take a look see .
2:52 PM
Fire it up, if it pops and snorts out the carb the reeds aren't seating . Those two saws mentioned should be 4 petal pyramids while the larger such as my avatar saw have 6 petal .I would have no idea where you could find replacement petals ,E-bay maybe ---more -
2:52 PM
In rereading what it said they say the petals should be tight against the cage
sledneck22
But, is the chain sharp?
1:52 PM
WI
I've had luck on the 925 series to flip the reeds upside down. But assure they are symmetrical and when I did that, they weren't open 1/16, more like 1/64-1/32. Just a little.
If you can't find new ones, this is what I would try. Or try and massage them straight once removed from the cage?
2:52 PM
I did some checking and if I'm correct those are Homelite #59628
