Philbert
Chainsaw Enthusiast
- 10:58 AM
- Jan 30, 2016
- East Dakota
How do you remove the sprocket?
Place a rag over it, and pry the spring clip off with a small screwdriver (unless you have the special cir-clip spreading pliers).How do you remove the sprocket?
I took it apart and didn’t notice anything out of the ordinary.
it actually sounds normal now. No high pitch squeal but now the chain doesn’t turn at all
That could be it. I tried running it with the case off and it spun. However when I put it back together the sprocket doesn’t turn. Not it is not doing anything but the battery making a beeping sound.Is it just a trick of the lighting or do the teeth seem a bit "flat" or short in places?
Almost like they might slip if the case has any flex or the bearings have much play.
A strip of regular notebook paper run between them should come through zig-zagy folded.
