- 12:29 PM
- Dec 3, 2015
- Banner Springs Tennessee
removed a massive amount of intake port material
Find another jug.
Did you take pictures of your work ?removed a massive amount of intake port material and no head gasket. Runs great but I’d like a little bit more power cuz it seems to bog easy. Or did I do something stupid???
Mastermind's assessment is correct.
Maybe not.....I'd like to see some pictures. But anytime I hear "I took a chit ton out" I figure it's fubared.
I will add that when I did mine, I only matched the intake to the boot. I did not go near the cylinder wall.
Not exactly “boggy”.Made it boggy?
That’s a better explanation of how mine is.Not exactly “boggy”.
It had great throttle response.
Just no azz
Find a new jug or you’ll be forever trying to chase gremlins in a saw that really isn’t worth fackin withThat’s a better explanation of how mine is.
Ok you’re going to have to help me. There a thousand ways to get numbers. What numbers do you want and how do I get them? Is it duration or port opening or closing? I’ve searched how to get timing numbers bet don’t get the answer I want. I don’t know how to find ###/###/###. As you can see I’m confused. If there’s a thread for that point me to it. Thanks
1. Please elaborate ...............1. May be your ignition timing is no longer in sync with your port timing. Sometimes, just opening up the muffler requires a change in ignition timing.
2. Your blow down # is also important (instead of just defined #s for Ex + Tr).
I thought the same thing. He must be lean down low or has poor atomization now. JB Weld will fix it.Made it boggy?
