wcorey
- 10:17 PM
- Dec 11, 2015
- ma usa
Does anyone else feel that strato saws need to be approached differently? Seems to me from staring at them that adding fuel into the strato ports is 2-fold. One being increase life of saw by bringing a bit more oil up top, two being if you're upping performance you can take advantage of using it like a larger intake.
Seems to me that all the fuel/mix that goes in through the crankcase has to go through the top also, however if you split it to route some through the stratos then you just have less through the crankcase where it's most needed.
And it is a larger intake either way, still can have more air going through, the air/fuel ratio stays the same either way by having a richer/leaner mixture in the carb tract. With the strato the final mix just happens further downstream and hence the "stratification".
I see the possible advantage strato has, whether combined or not, is in how it routes the incoming charge into the combustion chamber as compared to traditional transfers.
