Rare 154SG score
SawTroll
Information collector
1:12 PM
Troms, North Norway
Those old small Huskies,
I thought the same as Niko:
140 -> 240
340 -> 40 Practica -> 44 Practica -> 444
I believe the 444 came slightly before the 44.
Anyway, the 344s were FE/FG saws (Nordfeller attachment saws) only, and made alongside the 340SE/SG. The 444 came with all options, SE, SG, FE and FG - and replaced both.
raumati01
11:12 PM
New Zealand
Im still leaning towards 048 as i think the 042 av has a knob on the cover and the 048 is without.
Unless... the sticker is covering a hole ?
You are probably right, I tracked down some 048 parts for a mate who was rebuilding one and he might have had some 042 parts in the mix because the air filter cover was a hassle.
Spike60
7:12 AM
Ulster County, NY
Not to be rude here , but I think you deserve a big "you suck"! Very nice looking saw's. Are you a collector Bob?
Yes. Pretty much stick to the Huskys and Jonnys. That's what I'm a dealer for, so it's an easy fit. And naturally those are the saws that wander into the shop. Parts support is always "right there". So I'm kind of spoiled in that regard vs chasing parts for other brands for which I'm not a dealer.
I do also have around 20 Macs and Homies to cover the classic American thing.
rattler
7:12 AM
NC
Spike60
7:12 AM
Ulster County, NY
The 242XP below was my first. Got it along with a Jonsered 490 in a trade with Walt for a Solo 603. He likes the 603, and I've used both the 242 and 490 way more than I'd ever run the 603, so we're both happy. The 42 Special was only used a couple times and is super clean. I ran a tank through it last March, but she'll be doing more sitting than sawing. IMG_1274.JPG
Spike60
7:12 AM
Ulster County, NY
Just this one Tor. More in the Rancher time frame than the Practica era. But some saws had Rancher on the cover and Practica on the ID plate. Same as some saws had both SE and XP on them at the same time. This is one reason why these books are valuable, because not everything has been transferred into electronic form. Some incorrectly, and some not at all.
Simondo
12:12 PM
UK
The 242XP below was my first. Got it along with a Jonsered 490 in a trade with Walt for a Solo 603. He likes the 603, and I've used both the 242 and 490 way more than I'd ever run the 603, so we're both happy. The 42 Special was only used a couple times and is super clean. I ran a tank through it last March, but she'll be doing more sitting than sawing. View attachment 29832
Same saw..same bar , little bit of working over but nothing major ...1 early one without a Photo0662.jpg
de comp and 1 with. Mine do get used for the smaller stuff around the hedge lines.
Tor R
Novice, Leg model #2
1:12 PM
Mandal
I know to little about the history to 40 Practica, without beeing 100% sure I belive it belong to the 78 style, s/n is labeled Practica, but top cover isnt labeled Practica or Rancher, but I belive the top cover is the originale one since it has decor from the dealer who was the dealer at that time.
The IPL I need to get a proper scan of is 40-78, Huskies IPL on their homepage has errors.
Spike60
7:12 AM
Ulster County, NY
Same saw..same bar , little bit of working over but nothing major ...1 early one without a View attachment 29835
Yes, the first thing I noticed was that Windsor bar. The other saw also looks super clean.
Simondo
12:12 PM
UK
I tend to have a set of real nice clean covers scrounged from saws iv bought and keep them away from the work saws. Man that sounds Sooooo Anal :D!! but where are you going to find near new 42 cc 200 group saw stuff easy or cheep now !
Simondo
12:12 PM
UK
The little project I did with my 42 Special and a 45 back in March. Couple of 9" trees; no need for big saws. Lots of limbing. (and dragging brush out of the yard.) View attachment 29908
That is similar sort of work in the woods i have . I spend most of my time on timber 8-14 in and under ..some spruce some ash and beach. The valley is steep where i am turning the woodland back to a more traditional "coppice " nature so its mostly a 40cc class saws . Here's one for you Bob (please call me Simon if you wish)...the most popular size home owner saws that folks seem to end up with around me if there just cross cutting timber in a pile is 35-40cc. Wonder if you find the domestic cutter has such small saws with you as you sell them .
Any conclusions over the 45 and 42 sp ? you said in another post that the 42 sp will prob be on the shelf mostly.
Spike60
7:12 AM
Ulster County, NY
Simon, I'm pretty anal with the clean saws also. I'm a little easier on them and take a little more time to clean them when I'm done with them. Won't use them on pine. I do have some rough looking saws that I call "the rat patrol" that I don't fuss over. One more scuff mark is no big deal on any of them. The 42 will not see much use partly because it's so clean, but mostly because whenever I want to use that chassis, I'm going to grab one of the 242's. The 242 is noticeably quicker IMO.
The 45 is one of those "forgotten" chassis that few people talk about. Originated from Partner. Plastic, clamshell, (may even be the first one), so it's not cool. What it is though is very smooth. Anti-vibe way ahead of it's time. That 3 spring set up with the top one between the cylinder and the handle is pretty much the same as what we still see today; and they came out in the late 70's? Power on the 45 is between the 42 and 242. Muffler would be considered restricted on sites like this, but it's reasonably quiet. Don't always want a loud saw anyway.
In this area, 35-40 cc saws are occasional use/clean up saws. Some gals and older guys run them for firewood cutting due to the light weight and the spring assist starters that are on many of them. They can do a lot of work until the timber gets larger. Homeowner or pro, the starting point for most people who use a saw on a regular basis is 50cc. Timber is hard and can get big here. 55-60cc is common for homeowners. Serious and pro users are running 562's and 372's.
Simondo
12:12 PM
UK
No what you mean about having some workers , have a few of my "go to saws" that get maintained well but were never peachy when they were bought. The standard numbers back up the 242 v 42 thing as you say but with little work the 42 sp can gain a little zip and there much more available . Will look at the 45 more closely when i see any come up.
The pro/ tree climbers here are using the 50 cc class (346 and now 550) as ground saws by the chipper and the 372 /560xp are popular as well. Its just the home market that seems to end up being sold the likes of 240..135..435 etc or Sthils 171,181,211 . I tell you what Bob...if you have 242 xp ..254xp..346xp 357xp saws in good condition for sale here, then you have something getting Mighty hard to find ! Its getting so that a top notch 346 NE (2009 onwards) is about the 3/4 of the price of a new 550xp !
SawTroll
1:12 PM
Troms, North Norway
More like 2007 week 20 and onwards. ;)
Simondo
12:12 PM
UK
Yea , I can see what your saying with the silver Ne saws being 2007 onwards . The 2009 onwards saws really do seem to make the most money being that bit younger at only 7 yrs old .
Hell Niko ...thats almost a new saw !! :D
