Rakers with a Stihl USG
Hinerman
9:02 PM
NE OK
I have a raker wheel for my Stihl USG. It grinds the inside raker fine. The outside rakers produce a lot of chatter on the wheel (for some but not all the rakers). It looks like it wears the wheel out quick; I can feel small chunks of the wheel hitting me when it chatters and bounces.
Anybody else experience this grinding rakers (on any grinder)? Am I doing something wrong? Is there a fix?
The obvious solution seems to reverse the wheel direction for the outside rakers, but that is not an option.
Thanks in advance.
Wonkydonkey
Plastic member
3:02 AM
Sussex, UK.
What’s your settings. ? And Is the chain clamped good.
Ie stihl say ……
,see pics below…
I’ve got a usg and just got a new wheel as it never came with one when I got it 2nd hand. So I’m very intrigued, as I will be in your shoes at sometime in the near future 😉
Btw, If you don’t have the manual I’m sure i can send it .
10:02 PM
There might be some movement in the chain. When grinding the rakers on the back side, the chassis will flex slightly the way the wheel is spinning, which is away from the wheel. When you do the front side rakers, as they flex, that rocking action lifts the raker higher into the wheel causing chatter
president
7:02 PM
peachland BC Canada
Thanks in advance.
I turn the chain around in the vise for the second side ,presenting the raker away from protruding
and this avoids the chatter .
Hinerman
9:02 PM
NE OK
Probably the case. I was sharpening .063 chain; then went to .050 and .043. to do some rakers, without making any adjustments, because it is a minor inconvenience to do so.
Thanks for the input.
I don't see how this would work. Seems like the wheel will hit the cutter; and the wheel will be grinding the wrong side of the raker. got any pics?
Hinerman
9:02 PM
NE OK
Ie stihl say ……
,see pics below…
My settings are correct.
Wonkydonkey
Plastic member
3:02 AM
Sussex, UK.
Yes I agree with you.
In the manual, it says something about different guage chains and faffing about with spacers to clamp the thinner chains.
I didn’t get them spacers either 🤷‍♂️ and I thought about getting some washers instead 🤦‍♂️
Anyhow after all it was only about $350 I paid for my usg.. so I can’t complain to much.
But I’m still intrigued as I know I will be in your boots sometime soon 🤔😉
davidwyby
Rural desert logging
7:02 PM
Extreme Southeast CA
Just turn the chain around
Grind from inside like filing from inside
You might also be able to offset enough to get on the other side of the center of the wheel…but will probably affect depth
chipper1
10:02 PM
Grand Rapids Mi
How do you gauge the location of the chain?
I've done this for removing the back side of the cutters on racing chain, using the front side of the raker to gauge it.
