Raker shape
STOVE
2:57 AM
Eastern NC
Looking at different chains and one thing I have never learned much about is the raker profile.
These two Dukes models have very different profiles.
What affect does the shape have on cutting?
EFSM
1:57 AM
Extreme southern IL
Some of the difference is for kickback control. For instance, Oregon’s LGX chain has no bumper drive link, the LPX does. It is also for vibration control. Pic of .325 LGXIMG_1008.jpeg
singinwoodwackr
12:57 AM
moon
View attachment 483677View attachment 483678
2nd pic is like a 30+yr old Stihl chain…was great stuff back then. We preferred it to newer offerings due to less material to have to remove as the chain wore down. Less time with the raker file…
Duane(Pa)
It's the chain...
2:57 AM
Centre County
I have never been able to tell any difference from behind the saw. My smoothest cutting chains are the ones with the most consistent depth. That is something I have struggled with over the years. Mostly self inflicted. It takes patience to get them harmonious.
Some racing chains have an absolutely hideous looking raker.
DillonBuck
2:57 AM
Pa
Get a progressive raker gauge. The WCS is the best I’ve seen. It gives you depth options.
A simple jig that sets the raker for the tooth it controls, based on that tooth.
First used it on a well worn chain, immediately noticed how smooth it was.
The WCS is stupidly expensive for a business card size piece of steel. $14ish. But its hardened so it doesn’t file away. You can get the roller guide thing from Husky with a progressive gauge in it, it’s not hardened and wears pretty quick.
Sloughfoot
11:57 PM
Norcal
They are an excellent gauge. If you don't have a good memory best keep the little diagramed card handy that shows which slot is what, because it isn't on the tool.
Duane(Pa)
It's the chain...
2:57 AM
Centre County
So, I suppose you end up with a flat top raker? If that works, then we are sorta answering the question.
Philbert
Chainsaw Enthusiast
1:57 AM
East Dakota
I prefer to restore the depth gauges to factory profile, to minimize the risk of a sharp corner catching.
Use a flat file, Dremel, or Scotchbrite abrasive wheel (my favorite). Some guys profile their deth gauge wheels concave, to save a step.
Philbert
sundance
2:57 AM
SW PA
Philbert
Tell me more about the Scotchbrite abrasive wheel and how you use it please.
Philbert
Chainsaw Enthusiast
1:57 AM
East Dakota
Many people think only of ScotchBrite dishwashing pads. But 3M (and competitors) make abrasive pads, wheels, etc., in a wide range of sizes, shapes, thicknesses, abrasive types, coarseness, etc., from skin exfoliation up to floor buffing pads.
Sold through their industrial divisions for metal finishing, auto body paint repair, etc. Often referred to as ‘deburring wheels’, some remove material quickly; some leave a polished finish.
They can be pricy, but I look for surplus products resold on eBay, and try to be flexible.
Larger diameter wheels I use to clean / restore tools. For depth gauges, I look for 3” to 6” diameter, ‘unitized’ wheels, 3/16” to 1/4” thick, mounted in arbors on a bench motor.
Quick. Smooth. Look OEM.
Philbert
