Question about Mastermind cylinder cleanup method
5:42 AM
Gots to be very fast, and very thorough in the rinsing, as the alkali of the oven cleaner will consume aluminum
That's a no chitter.Don't dilly dally with it .Got it one and get it off ,fast .Nasty stuff .
beaglebriar
The Peanut Gallery
5:42 AM
Warren Center, PA
Anyone try a little piece of folded up 50 grit by hand? You know when you've busted through the aluminum transfer when it starts getting slippery.
That's how I do it but I don't clean up cylinders every day.
Takes a while sometimes but I've never ruined one either.
5:42 AM
i use flapper wheels on a battery drill and i have scotchbrite ball mounted also i like that design also closest harbor freight to me is uniontown pa a hour or so away
exSW
'Cause Thomas is a poopyhead
5:42 AM
United States
I looked on the website,couldn't find it. The packaging is gone so I can't get a code of it. I wouldn't want you to have to venture into Fayette County. 8-)
RIDE-RED 350r
5:42 AM
Blossvale NY
For sure! LOL! :D
Picked up some muriatic acid today. Going to try that method on the next one.
Thought I would add: The cylinder that started this thread had ALOT of transfer in it. Full width of the exhaust port above and almost full width below. That probably played a factor in my taking things too fa too fast.
4:42 AM
For sure! LOL! :D
I've ruined more with acid than I have by sanding. If the acid gets in a scratch, it will eat away under the plating. Also, be aware that the fumes are not good for you, or any metals that are near.
5:42 AM
I looked on the website,couldn't find it. The packaging is gone so I can't get a code of it. I wouldn't want you to have to venture into Fayette County. :cool:
lol ive only been to uniontown 2 times once to get tires almost 20 years ago for my buddys garage and to look at my cousins stepsons truck when he tore it up lol
5:42 AM
There is one 20 min from me, but their shipping rates are so reasonable (and fast) I often just "shop from home" if I see what I want on line and don't need it this minute. For example, they shipped 3 solar panels to me for $6.99 and it came it 2 or 3 days!
5:42 AM
I use acid first on most of them. I keep it out of the ports. I sand when I get close using a slotted nail with 80 grit and wd40 or whatever spray lube is close
5:42 AM
For sure! LOL! :D
I use acid and sandpaper. Sand first to get any of the oil embedded stuff off the transfer, then use acid on a Qtip, the sand again. Rinse with baking soda at the end to neutralize the acid.
I looked at your pics. The witness lines show you to be safe. I wouldn't even it out on the other side myself. So what if it's a bit assymetric.
You have a nice chamfer and the port roof is still nice and round.
I'd run it as is and I bet you'll be just fine. Opening the other side is gonna add more width and possible more problems. Unless you're chasing tenths, not sure why you would even it out.
4:42 AM
If it helps anyone, here's a pic of the set up I use sitting on top of a 3m flapper I really like and used on a 3 horse B&S engine. Would love a smaller one for saw cylinders but don't think/know if one even exists. Has the Scotch Brite padding between the sandpaper in layers.
5:42 AM
i have one of those also and havent found a smaller diameter one either
