- 2:51 PM
- Dec 31, 2015
- East Jordan, MI
If a guy ran that in a drill, he could wrap the sandpaper the other way and run it in reverse
This helps.If a guy ran that in a drill, he could wrap the sandpaper the other way and run it in reverse
yeah!!! it works wellIf a guy ran that in a drill, he could wrap the sandpaper the other way and run it in reverse
Egg Sack Lee.....If a guy ran that in a drill, he could wrap the sandpaper the other way and run it in reverse
They make 3 m flap wheels but because I don't do that many rebuilds I don't own any .Don't get yourself in an uproar about this,again it's not a race.get it right the first time ,
394 hasn't got a lot of room for widening the exhaust but you might be able to get it.Well, I'm going to be starting on my 394 overhaul after the holidays. I have not yet torn the saw down but I happen to have a spare 394 cylinder on the shelf that had some transfer and thought I would clean it up.
I made an arbor from a 1/4" bolt with a slot cut in it and the head hacksawed off and chucked it into a pneumatic die grinder. I wound some 120gr strip sand paper up in the arbor and largely it worked very well. BUT, as I was working around the exhaust port where all of the transfer was, I noticed that the sandpaper was enlarging the exhaust port on one side, the side the paper would drag out of. It actually looks like some nice, albeit excessive port window tapering. My concern is that I'm going to have to match up the other side with a burr and I have seen it said that one must use caution when thinking about widening the exhaust on the 394. I was also wondering what I'm doing wrong to cause that alteration of the port window?? I was able to remove all but a tiny tiny bit of transfer just above the port on that same side. It is almost gone but still visible, but cannot be detected by the fingernail test. This is the second time I have cleaned a cylinder using this method and had this result of altering the port window on one side as a side effect of the operation. Is this a problem or am I overthinking it??? I'm sure I can match it up and even things out with a burr, but how does one prevent this if widening the port is not intended to be done??? I wonder if I need a reversible grinder to avoid this... Maybe muriatic acid is the better method for me??
Thanks
Pics show both sides of exhaust port for comparison.. I'm afraid I just ruined my cylinder..
View attachment 44538 View attachment 44539
When it comes to salvage work, I use marvel mystery oil, a combo of sanding rolls, alum/oxide cloth, scotch brite, an aluminum arbor and a light touch with my foredom hand pieces,,, plenty of lube, no more speed than you need is always bestYou didn't fork it up I don't think .However just as an opinion you'd be better off to do like Randy with 3M
scotch bright than sand paper .And use some kerosene or something,don't ever do it dry
I got in a hurry once and used too course of a flap wheel,never again.It's not a race .
The key is to stay away from the port edges.
Gots to be very fast, and very thorough in the rinsing, as the alkali of the oven cleaner will consume aluminumEasy off oven cleaner will work too .My Lawdy that stuff stinks .I don't go that route either unless there is a lot of transfer .
