TJ the Chainsaw Mechanic
Old Homelites rule!
- 12:22 PM
- Jan 7, 2016
- Next to my bench at the shop, Oregon
Hotter Spark plug.
Here's another thing on those giant holes .Timberwolf AKA Brian Wright had a spread sheet presentation on muffler holes as a percentage .He found that much over 80 to 85 percent of the area of the exhaust port added almost nothing to performance.He took it out to 125 percent if I recall correctly .Just sayin
I as well believe there is a point where its worth stopping. Now i don't profess to have the understanding of the subject in full but" without" the sort of detailed port and time-work done by some of the fellers here..i tend to go for 70-75% of exhaust port sq aria as my muffler output hole size. It always tends to be a very large increase in the standard output anyway.Here's another thing on those giant holes .Timberwolf AKA Brian Wright had a spread sheet presentation on muffler holes as a percentage .He found that much over 80 to 85 percent of the area of the exhaust port added almost nothing to performance.He took it out to 125 percent if I recall correctly .Just sayin
With a longer blow down it only makes sense it will blow some fuel straight through it
Longer blowdown spitting fuel out of the muffler?
Got that backwards brother Al?
With all due respect, I'm going to have to agree with Al.
Ill be the first to say i couldnt care less how much fuel my saw uses (within reason). I dont climb trees or do production felling, and i understand the utility of fuel efficiency for those guys, but, for cutting firewood and occasional felling, im usually ready for a break before my saw is, so burn it all!!
