Pulling Bearings: Tips/Tools
Nutball
10:54 AM
Mt. Juliet, TN
For people wanting to pull bearings off a clamshell engine shaft, what pullers do you recommend and what tips do you have (heating, freezing, oil, ect)?
I just realised the crank stuffers on a worn out 271t crank might fit my 352 crank, so I'll need to pull off an old set of bearings and pull and reuse the new set on the 352 without damaging them. If anyone has has a favourite budget bearing puller, or a good method for removing bearings without special tools, I'd like to hear it.
davidwyby
Rural desert logging
8:54 AM
Extreme Southeast CA
Now a saw expert...but machine/welding/industrial mechanical guy.
Freeze all of it.
Warm bearings gently but quickly, not the crank. Use whatever puller is handy and fits.
Nutball
10:54 AM
Mt. Juliet, TN
The 271t crank weight diameter us 47mm, 49mm on the 352, think it will still work? I tried looking up the 355t stuffers and it seems they only come in a factory engine, and not separately or even on replacement cranks. o_O
11:54 AM
