- 11:22 PM
- Dec 28, 2015
- Central Ohio
a light bead of oil will get sucked into the vacuum leak, not as easy as a pressure leak but necessary and you can use a drop of oil on the end of the impulse line to check your impulse pulse by turning the crank slowly by handYeah but how we can spot from where we have vacuum leaks ? for the pressure we have the soapy water what we have for the vacuum ?
Dave
