Power sharpening on the saw
Lightning Performance
8:02 PM
East of Philly
As the title says. The power supply voltage does not matter. AC/DC 12v-240. Keep in mind that saving time was the purpose of the thread.
I had a 12v dremel type with a stone and guide. IMO it sucked and not in a good way. Did more burning than sharpener. Post up a video of some in use or links.
jakethesnake
I Am The Snake
8:02 PM
Here & Now
I have a 12 v stihl sharpener. Works alright. Needs a new stone.. I quit using it as I can swap a new chain in faster
Carhartt
8:02 PM
Central Pa
Is there any RPM adjustment on the 12v Dremels? I am assuming not. Is that the reason for the burning on the tooth?
1:02 AM
Local supermarket currently has a Dremel type grinder, 12Volt DC, Li-Ion battery, 0-22k rpm.
I've been eyeballing it, but so far didn't find a justification to purchase it.
Duce
8:02 PM
Roscommon, MI
I use a Dremel with diamond stone. Think it's not about rpm, but more about pressure causing burning.
Carhartt
8:02 PM
Central Pa
I know sharpening a poor quality chain with a grinder it doesn't take much to discolor the tooth. Be gentle n slow it might change results.
davidwyby
Rural desert logging
5:02 PM
Extreme Southeast CA
Old post I know. (I'm starting from the back and working fwd)
I use a dremel stone in a variable speed reversible drill for touching up, mainly while milling. If you wanted to remove more material faster, such as on a rocked chain, a carbide burr and more RPM might be the ticket for avoiding heat.
Pic in this thread: First time milling, got creative | Outdoor Power Equipment Forum (opeforum.com)
1:02 AM
Another funny one, chainsaw cutter belt sander, You need a cordless drill to run it.
They want 285€ + VAT and You do not get a cordless drill with it!
Seriously!!! o_O
1:02 AM
Problem with those Dremel or Stihl type rotary tools is if you use the stones they quickly wear and lose their diameter/profile. Diamond bits solve that issue.
True! :beer-toast1:
Dennis Coon
11:02 AM
I want one of those hand powered grinders.
They might be ok once you get the idea of how to use them.
Shouldn't be any burning.
Probably be a collectors item one day
