Post up your ported cylinder Artwork
Nutball
12:47 PM
Mt. Juliet, TN
Are you using a stone or a carbide burr to cut your ports?
Carbide. Sometimes I get a good finish and polish from there, but seemingly randomly the carbide bit won't get the good finish I'm looking for. Sometimes it's how steady my hands are at the time. I've found I don't much like the rubber abrasives from CC that I've been using. They don't seem to remove material as fast at the dremel polishing wheel I have, but leave big scratches, and they seem very inconsistent: sometimes polishing a near mirror shine and other times scuffing the surface.
1:47 PM
Try single and double cuts. Alumahogs when you get steady.
I find that double cuts are the best for initial cutting of plated area and ports (after hogged) and then a single cut rounded tree 1/4 x 1/4” is best at a certain rpm for finishing. At the correct rpm, a single cut finish can get close to a sanded finish.
Looks like you are pressing too hard trying to remove too much material at once. Get an alumahog and try it, just dont use near the plated part of the port, finish that area last with a standard burr.
1:47 PM
NW CT
Sage advice here. I found the very tight single cuts give an excellent finish that is very easy to sand smooth and then polish. The more aggresive double cut pulls out material quicker but leads to much longer time with the emery cloth.
Nutball
12:47 PM
Mt. Juliet, TN
Yea, I'm experimenting with different pressures. I've found too little pressure with a double cut or hog will bounce around, and the best finish is from enough pressure to get a good smooth cut. I had lots of material to remove from the exhaust, so I tried too speed up progress with pressure. I just can't get the hog too close to the tight corners. That leaves a lot to go with the double cut.
I do need to get some single cuts. I have a 1/8 double cut rounded tree I tried on that cyl for just a minute, but I couldn't get a smooth cut out of it. Just a lot of vibration.
Chainsaw Jim
Con Artist LLC
10:47 AM
Springfield Oregon
I use this double cut and dip it in water to keep it cool and lubed. When I get ready for finishing I'll put a few drops of clean motor oil on the water and use it as a polishing compound on the double cut for a near mirror finish. A slower rpm, almost no pressure, and quick moving will give the best results.
The oil on the teeth gum up with aluminum dust and turns it into a very fine polisher. 20190205_043447.jpg
1:47 PM
NW CT
The oil on the teeth gum up with aluminum dust and turns it into a very fine polisher. View attachment 163310
That is brilliant. I’m going to have to try that
