Post up your ported cylinder Artwork
NateSaw
11:53 PM
Maryland, USA
Far from artwork... My new employers 660. Hopefully it makes some power. Trying to implement what you all have been sharing/teaching. My hats off to you guys. This is some challenging *s-wordz.
NateSaw
11:53 PM
Maryland, USA
New right angle hand peice needs a trained hand.... It works too good.
11:53 PM
It is often hard to tell from pictures, but it looks like you have a lot more arch on the top of your exhaust than on the bottom ... why? You can hang a ring in either direction. Make sure the bottom of the port is well beveled.
I also think you can add some performance by reducing the arch on the top of the exhaust port. It made a significant difference on one of the 660s I played with.
NateSaw
11:53 PM
Maryland, USA
Thanks Mike! Yeah the exhaust isn't shaped much from stock. It came in a 97* degrees after lathe work, so I thought I'd try it there. I widened by about 1mm on either side is all. I blended and polished to that. Barely scratched the nikasil on the floor and roof. I have a feeling ill be back in this one. The transfers didn't turn out as I wanted. And I overshot the intake at 85*.....I'm thinking the lowers may need a bit of shaping to increase what's being forced into those lazy looking uppers... Idk. One thing I don't like is that when the intake is opening, you can see both rings at the roof of the exhaust.... Maybe I'll need to epoxy the floor... I'm also looking at maybe that cross MMWS cylinder 👍
NateSaw
11:53 PM
Maryland, USA
srcarr52
11:53 PM
Iowa City
I'd use the Dukes reserve 660 kit before the Cross.
farminkarman
I like the red & black ones
10:53 PM
Neenah Wisconsin
11:53 PM
Some of the Cross cylinders I got were VG, but #s were generally all over the place (except for two that I ordered at the same time that seemed like twins), and other folks had problems with them that I luckily did not encounter.
Therefore, I'm glad to see you guys recommending a more consistent alternative. I don't think they were available when I was doing my 660 projects.
