Iron.and.bark
- 3:11 AM
- Feb 26, 2016
- Australia
Interesting posts guys
Now my issue is with the fact that porting/modding a saw seeking more torque is pointless. I actually wanted to title the thread rpm vs torque, but choose to respond to a statement that had been made.
My 3120 story.
Got myself a nice 3120, fixed carb,stock muffler and unlimited coil we have over here.
Slabbing in an alaskan mill. 8 tooth sprocket, 3/8 skip tooth chain (credit me with know how to setup a milling chain properly) and ~30" log. When fed in carefully would cut, apply to much pressure and it stalled and burnt up the clutch. Saw does never reach max rpm and hence max HP.
Switched to 7 tooth sprocket, saw would still stall and could not fully lean into milling cut.
Modded muffler.
Switched to full comp, saw cut at same speed (around ~8-9k rpm) and obviously milled faster due to more cutters. Could still bog if you tried Really hard to.
Pulled cylinder and widened exhaust port (not raised).
Full comp, 8 tooth .404 was able to be run. It liked it
Now what had increased?
Not rpm as it remained approximately constant.
Since as the "Boss" around here said
HP = torque x rpm
HP must have increased, and what enabled that was torque. When I say increases HP, I should clarify it by saying HP at that given point in rpm that the saw operated at.
A 2 stroke used in a chainsaw is a whole series of compromises. You are trying to make the best use of an imperfect machine to do an imperfect job and if you are like me an imperfect operator
My point being you can point the compromises in more than one direction as jobs go in more than 1 direction
Oh and when next summer we take out a section of 40yr old pines, I sure as hell would love a JMS saw
My 3120 story.
Modded muffler.
HP = torque x rpm
