- 11:36 PM
- Dec 29, 2015
- Strong Island NY
Hey Red13.5,
Wake up. Joe, wake up.....!!!
Man you guys are a rough bunch! We need him to be in top physical shape to do this little beast justice vs an Echo that can turn a 32" bar.
No kidding on the no sleeping when you have a baby. My first didn't sleep the entire night for the first 14 mons.....
Ya got to take care of family first. Saws can wait[emoji6]I'M UP, I'M UP!
Fired the saw this morning. Seems to have a bit more attitude..
Sorry guys life got in the way. At the dentist with the gf, she may have to get a root canal or wisdoms pulled.![]()
Excellent job there Sir...lot of work went into all this info.
Not as much of a gain as I was hoping for, had a couple variables working against me, the test log had grown a bit and couldn't resist a few test cuts on the chain.
Figure it gained 500-800 in the cut and a broader powerband. This thing has torque to spare.
My tach must be faulty.. no way I got 2 saws in a row with the coil limited 3-500 below spec. This limiter kicked in at 13,000 on my tach. Saw is set 12,800 in all cuts.
First comparison. The bars are 68dl
Dolmar 42cc vs 50 for the echo.
This is my limbing test lol.
You may notice the dolmar isn't quite as snappy, think it has something to do with the giant flywheel.. close to the same size as a 372...
https://youtu.be/BeK6i9xuW78
https://youtu.be/pFXhe3lfOkg
Figure this is the more the size wood the dolmar was intended for.
The echo is definitely more wild feeling. Don't think the results would change much with the stock af/and carb.
The dolmar is noticeably smoother in the cut.
In the hand both saws feel the same. Weight and bulk.
Really don't think a lot more is to be had with the 421 without a coil and carb change. It feels about the same weather you are cutting 4" or noodling bar buried. Might not make a cant racer, but I think it is a damn good firewood setup.
My summery,
If you want a solid built, smooth saw get the dolmar.
If you are looking for an underdog with a attitude grab the echo.
Joe with all the extra torque, do you think a higher exhaust or maybe a little less blow down could help speed her up a bit?
