MAF143
- 2:19 PM
- Mar 30, 2021
- North Central Ohio
Huskie 357 that I just picked up from one of my wife's highschool classmates. He had just put a new bar and chain on it. It has some issues but even with a filthy air filter it was a tad faster than my MS362C with a MM, timing advance, and square filed chain.
It's missing the duck bill vent and filter. The one AV mount needs a new screw.
The plan is to put in new bearings and crank seals, new intake rubber and metal clamp, new caber ring, and some other misc. parts that are missing, cracked, or broken.
The timing numbers without the base gasket are:
exhaust: 108*, 144* duration
intake: 73-1/2* for 147* duration
x-fers: 126* for 18* of blowdown
squish: .020"
The plan is to raise the exhaust 4* about .030" to get 152* duration and widen the port (haven't calculated that dimension yet). This should move the blowdown to 22* (there was carbon in the upper transfers)
It will get sanded down to 320 to get it pretty smooth.
Lower the intake 3* about .025" for a duration of 153* and widen it some (haven't looked at the dimensions for that yet).
I won't touch the upper x-fers. The lower transfers will get some opening and matching to the cases for improved flow.
The muffler, gasket, and heat shield will all get opened up a tad and matched to the port exit.
I have a cheapo aftermarket Muffler on the way to play with as the stock one is actually kinda complicated and I don't want to hose it up yet without playing with this other first. I haven't really pondered on this yet and was hoping for some suggestions from the crowd here as how to deal with this muffler. It has a couple baffles inside and a tube it looks like. I haven't taken it apart yet to examine it closely. I was hoping it would be a two piece muffler but it's rusty and it has resisted coming apart at the seam so far. Are these welded closed or just rusted enough that it needs some persuasion?
Advance ignition timing 6*
Squish looked good at .022" with the base gasket gone.
This saw has the crank stuffers that lower the crankcase volume.
This is only the third saw that I have ported and I'm trying to stay a little on the conservative side. Am I on the right track or am I gonna ruin this saw? These numbers look to be an improvement while still being on the mild side. I'm not looking for a wild saw, just a strong running work saw. The other two I've done (other models) have shown nice gains but I have approached this with baby steps and stayed conservative.
squish: .020"
