- 2:02 PM
- Dec 29, 2015
- Strong Island NY
You don't need to polish the exhaust anymore than you already have. It's useless.
I'm a bit concerned about your intake port. You needed .100, not under a mm (.040) on each side. There are ring gaps there. The area to keep slightly rounded were the roof corners, not the floor corners. Make sure that both ring gaps stay tucked up under your roof. You don't need to run the bottom ring and I wouldn't if it's into/near the port. Be careful with your chamfers. Keep em tight by the intake roof and walls.
How do you plan on raising the transfers? Do you have a right angle tool?
Assemble and look at the geometry. Get your numbers. Draw a line on the piston at BDC. Check your ring gaps. Report back. Don't raise transfers yet.
