porting a 064 hybrid.
Definitive Dave
Piss Rev Mafia Member
8:20 PM
Central Ohio
so do you know why?
cause awesomeness attaches itself to everything I touch?
Sounds like treemonkey has a deep dark secret he wants to share :)
I wanna know the answer even if I wont really understand it, cause someday I will.
Dave
czar800
8:20 PM
Ellwood City
Dave
Some day Dave the GREAT Monkey of the Tree will speak and blessings of port numbers will flow over the land like milk and honey, just continue to woo him with your charms and good looks.
Tractorsaw1
7:20 PM
SHOW ME MO
Yep that's about all I build anymore.
Work saws are boring and for work,yuk
Pretty much all my saws are for playin, I cut my firewood for 4 years with 064 hybrid & 20" bar. That kinda makes the 60cc saws seem like there lacking something
psuiewalsh
Basement Bodging
8:20 PM
Nottingham,pa
Curious why the 046 has 6mm and these 5?
Maybe they found out the case threads were stripping. I think both the 044 and 064 are 5mm and the 046 and 066 are 6mm, so it was an engineering fix. I have had a couple 064s with stripped holes and even 066s too so my vote is the case is the weak connection.
Definitive Dave
8:20 PM
Central Ohio
The base on a 064 is thin but everything else is thick so maybe when they needed longer bolts they stepped up a size. Maybe?
"they say" the super early 066 redlight with the thin base is the boss of all stock runners, if that isn't just a bunch of hooey, is the thin base part of what makes the 064s so much fun to run?
jmssaws
Banneded
7:20 PM
I don't think so,a 064 has good timing numbers from the jump and so did the early 066's.
One of my red light saws had a thin base and one does not and both are original,the same guy bought them both new and they both had the big end bearing let go.
