ported 661 - testing 7 and 8 pin .404
Keith Gandy
Maxima K2 40:1 87 Pump Gas
4:39 PM
Provencal, Louisiana
No more of a difference in speed as that is I would take full skip just for clearing chips noodling but thats because I noodle alot
Chainsaw Jim
Con Artist LLC
2:39 PM
Springfield Oregon
This is a good example of why I stopped running an 8 pin on larger wood. It's close enough to call the same cutting speed but there's more lug with the 8 pin. Limbing and smaller wood is where the 8 pin really shows its advantage.
I prefer full comp too. You can straighten up the sides of the rakers if you're having binding or chip clearing problems.
Redbull661
661 hoarder (BlueBallz)
4:39 PM
wisconsin
7 or 8 rs or 8 on the full skip - they all work real nice.
At 28" this particular saw has the balls to pull 8pin .404 RS full comp is faster than 7pin.
At 36" this particular saw the 7pin .404 RS full comp is just slightly better on the speed and better on the torque.
In 3/8ths I think I'd have to run 9pin full comp to realize the full potential...maybe even at 36".
I ran a lessor ported 661 with the 28" .404 RS right after this one in the same log. 7pin was faster than 8pin. So that particular saw obviously didn't have as much power.
point - I think it depends on the saw.
Chainsaw Jim
Con Artist LLC
2:39 PM
Springfield Oregon
3 tenths of a second difference is basically the same exact speed when it comes to a chainsaw cutting a round of wood for non-competition. I predict the same saw will cut faster in bigger wood with the 7 pin.
Deets066
AKA Deetsey
5:39 PM
3/8 - 9 pin is bigger than 404 8.
You saw has plenty of power to pull 3/8 - 9 pin at 36" bar. But it's hard on everything
Brewz
9:39 AM
Hunter Valley - Australia
I tried my 066 with an 8 pin and 404 Stihl RS on a 25" bar and it stretched the chain.
I have used it a lot with a 7 pin and the difference I noticed in hardwood noodling was that it was spinning so fast I had to push it into the wood to really get it cutting
Brewz
9:39 AM
But when it really bit in, the noodles were landing 20 feet behind!
I will agree with the above comment saying the speed difference is negligible when cutting fire wood in big timber.
I find a 7 pin better due to less vibration, less load on the clutch and chain, better throttle response, increased torque.
The 8 pin would work well in smaller timber but I no longer bother, even with 3/8 chain due to the extra discomfort that comes with a couple 10th's of a second faster cut.
Plus we dont have much in the way of soft timber here, its all hard unless you are pruning roses.
Brewz
9:39 AM
Yep
At what point does a couple percent faster cut time become a good trade off for increased wear and stress on the saw and user?
I have a .325 9 pin sprocket and have not used it, but one day I plan to fit my little 16" 325 bar up to my 066 with the 9 pin and see what it will do :)
In Aussie hardwood, I recon it will cut as fast as it goes blunt!
Moparmyway
Its just a saw
5:39 PM
In a meeting
Yep
In Aussie hardwood, I recon it will go blunt faster than it cuts !
Fixxed it for ya !!!
