Redbull661
661 hoarder (BlueBallz)
- 2:30 AM
- Dec 31, 2015
- wisconsin
trying some different combos in .404 7 and 8 pin @ 28".
3 tenths of a second difference is basically the same exact speed when it comes to a chainsaw cutting a round of wood for non-competition. I predict the same saw will cut faster in bigger wood with the 7 pin.At 28" this particular saw has the balls to pull 8pin .404 RS full comp is faster than 7pin.
3/8 - 9 pin is bigger than 404 8.7 or 8 rs or 8 on the full skip - they all work real nice.
At 36" this particular saw the 7pin .404 RS full comp is just slightly better on the speed and better on the torque.
In 3/8ths I think I'd have to run 9pin full comp to realize the full potential...maybe even at 36".
I ran a lessor ported 661 with the 28" .404 RS right after this one in the same log. 7pin was faster than 8pin. So that particular saw obviously didn't have as much power.
point - I think it depends on the saw.
+1 same hereI noticed better fuel mileage with a 7 tooth and I also saw reduced clutch wear with the 7 tooth as well
Couldn't agree more there3/8 - 9 pin is bigger than 404 8.
You saw has plenty of power to pull 3/8 - 9 pin at 36" bar. But it's hard on everything
Yep
At what point does a couple percent faster cut time become a good trade off for increased wear and stress on the saw and user?
I have a .325 9 pin sprocket and have not used it, but one day I plan to fit my little 16" 325 bar up to my 066 with the 9 pin and see what it will do
In Aussie hardwood, I recon it will go blunt faster than it cuts !
