tree monkey
- 10:35 AM
- Dec 14, 2015
- wi
I'm going to HELL !!!!!
see ya there
That's why with a wj69 it doesn't do it.it's not limited by spark, it's limited by fuel
Yuppers, i do ......... mine and two others that are with tree servicesAny of you other guys have one with a pop up?
I've got several, one on the saw too. Matter of fact, a large portion of the Ct GTG crew saw it and a few ran it. I even brought it with me the following week to Dans. She holds Above 13,000 with a 25" 404 8 tooth now .............I flat out told you what was wrong with your saw.
and your trying to blow smoke up our asses saying your saw runs 13.100 in the cut, stock carb, no pipe, pump gas, and you don't own a tach to show it.
My 661 is not easy on fuel. In fact it loves it. 3 trees to the tank in big timber.the mtronic can deliver way more fuel then you think. I've tested it. if your running the mtronic out of fuel there's no way the saw can be easy on fuel.
Yeah, mine gobbles fuel too, but it's still way better than any 066/660 on mileageMy 661 is not easy on fuel. In fact it loves it. 3 trees to the tank in big timber.
I don't have any 660/066s ported.Yeah, mine gobbles fuel too, but it's still way better than any 066/660 on mileage
I build work saws every day.
I build 661's that don't pop to but the popping saws are the ones customers want all I can get and those are the ones I post about.
I don't try to get all of it on every saw,I port every day same as you.
The only ones I ever post about are the play saws which ain't no different really.
This popping 661 is 100 118 85 175lb of compression and stock mtronic and runs perfect and is easy on fuel and will idle all day. That's a work saw to me
I don't know how to build anything else.
I bet if I posted a video of a common running 661 in this thread nobody would have said a thing.
95 / 116-118 / 82with the port numbers he posted?
Umm ........With a dull chain, and high depth gauges.... yes![]()
Umm ........
I'm pretty sure that I've got sharp chains, rather aggressive rakers, and overall they tend to put a hurtin on the average 90cc saw
404 8 tooth in rock hard crotch of a dried out hickory ......... chips don't lie
Indeedmtronic?
My bad ....... I'll pull my head outta muh arse nowDon't take what I say so serious.....
Be careful. Don't get your ears hung up.My bad ....... I'll pull my head outta muh arse now
Or your vaginaBe careful. Don't get your ears hung up.
