ported 661 baffle in muffler vs baffle out
jmssaws
Banneded
4:52 PM
it's not limited by spark, it's limited by fuel
That's why with a wj69 it doesn't do it.
That's also why I wonder what people are ordering a unlimited coil from Europe but maybe it helps because I believe it's limited by both or when you put a standard carb on it gains rpm but it still stops or at least with a 4700 it does.
Moparmyway
Its just a saw
5:52 PM
In a meeting
Any of you other guys have one with a pop up?
Yuppers, i do ......... mine and two others that are with tree services
I flat out told you what was wrong with your saw.
and your trying to blow smoke up our asses saying your saw runs 13.100 in the cut, stock carb, no pipe, pump gas, and you don't own a tach to show it.
I've got several, one on the saw too. Matter of fact, a large portion of the Ct GTG crew saw it and a few ran it. I even brought it with me the following week to Dans. She holds Above 13,000 with a 25" 404 8 tooth now .............
tree monkey
4:52 PM
wi
with the port numbers he posted?
tree monkey
4:52 PM
wi
I build work saws every day.
I build 661's that don't pop to but the popping saws are the ones customers want all I can get and those are the ones I post about.
I don't try to get all of it on every saw,I port every day same as you.
The only ones I ever post about are the play saws which ain't no different really.
This popping 661 is 100 118 85 175lb of compression and stock mtronic and runs perfect and is easy on fuel and will idle all day. That's a work saw to me
I don't know how to build anything else.
I bet if I posted a video of a common running 661 in this thread nobody would have said a thing.
these port numbers are going to produce 13,100 in the cut?
Moparmyway
Its just a saw
5:52 PM
In a meeting
With a dull chain, and high depth gauges.... yes :)
Umm ........
I'm pretty sure that I've got sharp chains, rather aggressive rakers, and overall they tend to put a hurtin on the average 90cc saw
404 8 tooth in rock hard crotch of a dried out hickory ......... chips don't lie
maulhead
3:52 PM
Colorado
Umm ........
Don't take what I say so serious.....
