ported 661 baffle in muffler vs baffle out
tree monkey
1:57 PM
wi
What do you think it is?
It does it just like a 4 stroke, worse cold.
No load wfo is the same sound,lift in the wood it's the same.
Not a single thing I've done made it stop.
I can take power away and make it better but that's it.
Does it with a wj69 also
It doesn't it with a carb
better get your story straight
jmssaws
Banneded
1:57 PM
You are the only one that really worries about that.
I've been backing away from all I can get on these saws for years.
Building a solid workable saw is far more important that getting all you can. You'll see that one day.
I build work saws every day.
I build 661's that don't pop to but the popping saws are the ones customers want all I can get and those are the ones I post about.
I don't try to get all of it on every saw,I port every day same as you.
The only ones I ever post about are the play saws which ain't no different really.
This popping 661 is 100 118 85 175lb of compression and stock mtronic and runs perfect and is easy on fuel and will idle all day. That's a work saw to me
I don't know how to build anything else.
I bet if I posted a video of a common running 661 in this thread nobody would have said a thing.
jmssaws
Banneded
1:57 PM
My dt303 stihl tach won't read a limited saw
jmssaws
Banneded
1:57 PM
You just said what I was thinking. Personally I could care less if someone on here has a ported 661 that would cut circles around mine and make it look like a hack saw. Mine runs great starts easy and is reliable. That should mean more than anything. I'd rather have bullet proof reliability than the most ultimate powerful cuts so fast it's like it's got a laser for a bar and chain powersaw.
Why isn't this saw a work saw?
It's less compression than anybodys and runs perfect.
What makes it not a work saw?
Redbull661
661 hoarder (BlueBallz)
1:57 PM
MN
dam it I ran out of dew, i'll be back
maulhead
12:57 PM
Home
So in summary, if I take the baffle out, I might be able to rent a pig, however if I leave the baffle in, my only choice is to rent a goat.... did I get that right?
What does it take to get a Dr pepper, over a mountain dew?
1:57 PM
I've reached a conclusion.
I like turtles.
