Pneumatic blowgun
wildroamer
Winning!
5:16 AM
Vermont
Hey gang,
I just ordered an air compressor, and am looking for input on what you all like for a blowgun as attachment for cleaning Chainsaw. Style, etc.
Thanks,
wild
P.M.P.
Stiff Member
5:16 AM
Michigan
I attached a hose to the end of the blowgun that came with compressor works good for me.
wildroamer
Winning!
5:16 AM
Vermont
What compressor did you buy
I ordered a little CAT 4610A. I was looking hard at the Rolair JC10, but thought 2 1/2 gal tank was maybe too small. The Cali Air has 4.6 gal tanks, only 5 lbs heavier than the JC 10, and same 60 dB spec.
czar800
5:16 AM
Ellwood City
I've been using a few different HF blow guns with no problems.
Agent Orange
Stihl trying
4:16 AM
KS
Ugh, I'll type this again. I've had the old style Vacula for almost 18 years, still works. Acquired a couple knock offs that have cracked at the plastic where the metal tube joins the body.
cantgitright
i am Mastermind's other profile
5:16 AM
right place at the wrong time
I didn't know air guns were such a hot topic? I just use the regular ole coilhose ones like this....
ditch the safety tip and install whatever type of end I need......I have a bunch with all different ends
cantgitright
5:16 AM
ive never really likes that style...all that plastic doesn't seem to last around me, and you cant change the tips....
the ones I posted have the 1/8" NPT threaded end so you can add whatever you want to the end...a lot of mine are setup with male quick disconnect water fittings to blow out the water jackets on injection molds...
stihl sawing
4:16 AM
Arkysaw
That's basically the one I have, Probably have four different kinds laying around. I have a long reach one that I never use much. The one you have pictured stays on the hose all the time unless I put an air inflation chuck on it. never had any trouble with it and it's several years old.
jakethesnake
I Am The Snake
5:16 AM
Here & Now
I do lots of blowin on air filters an *s-word seems the more I pay the quicker they die or I lose em... Runnin a walmart job bout like ol man can't showed it's acceptable
