pico vs .325 vs 3/8 for residential light duty
davidwyby
Rural desert logging
10:29 AM
Extreme Southeast CA
That "chip sweeper" mod with the safety chain is slick. I have always removed the humps completely, but it sure looks faster with the chips getting cleared and not under the rakers. Thumbs up.
Coincidentally, I have been testing it in felling situations where chip pileup is an issue, and it seems to work well.
davidwyby
10:29 AM
This is 3/8” low pro. The sweeper leaves the stump almost clean.
Philbert
Chainsaw Enthusiast
12:29 PM
East Dakota
I’m confused: what is the ‘chip sweeper mod’?
Thanks
Philbert
president
10:29 AM
peachland BC Canada
There are lots of options for chains:
Pitch - .325" is slightly smaller than 3/8 (technically .365"), so it takes more, smaller bites of the wood. This makes it smoother in smaller diameter wood.
Low Profile - 3/8 is available in low-profile versions (STIHL calls theirs 'Picco') which also take smaller bites of the wood, and let’s lower powered saws keep their revs up.
Narrow Kerf - narrow kerf chain takes thinner bites of the wood, and makes lower power saws cut like more powerful saws. There is narrow-kerf .325 chain, and now, narrow kerf AND low profile .325 (Oregon 'Nano') and 3/8 chain (Oregon Type 90, and others): this is being supplied on some of the newer battery powered saws.
Manufacturers generally choose what they think the best performing combination of drive sprocket, chain, and bar is for a saw. Users are free to change these. Just understand that the 'standard' parts will usually be easier to find down the road. 3/8 low profile, .325, and .325 narrow kerf chains are widely available.
I run .325 narrow kerf chain on a Husqvarna 353, which could pull standard .325. But that's what came with the saw, and I am really happy with the performance. I would be reluctant to put a low profile chain on that saw, because it is capable of running the larger format, and I would not be using the full potential of the saw.
Philbert
good referance
