chy_farm
- 12:13 AM
- Jul 3, 2017
- Yokohama, JAPAN
Making an exhaust port of a pipe seems always to be tricky to me, since the port at the engine side is most always rectangle while the sectional shape of pipe is round, so we have to make a 'converter' , I call it so, to help the high temperature gas flow going as smoothly as possible at this part.
Here showing the muffler from 740, the flange is cut apart and sitting in the left which is to be used for this pipe also as a flange. ;
Make a rectangular 'pipe' which has the same length for the four sides of this rectangular exhaust port.;
Weld them together. ;
Give modification to the shape. ;
The circumference of this round end should be the same as that of the pipe we are going to build. ;
Chy
Chy
