Old McCulloch with Pipe
T.Roller
12:10 AM
Southeast, TN
chy_farm
1:10 PM
Yokohama, JAPAN
12:10 AM
Good morning my friend, sorry for being late here to say thanks to you. Time flies....there are still many fun projects undone, lol.
Chy
Same here but not so much fun flooring to do.
I have several customers saws to fix as well.
What you do takes much longer.
Modern saw's are easy to fix usually. 20170710_161516.jpg 20170710_160916.jpg
chy_farm
1:10 PM
Yokohama, JAPAN
------160 degrees for closing. ;
But one failure was that I did not make a check on her transfer port timing . Instead I put 150 degrees for this parameter which gave me this design below as a result, ;
So I made a check again on a 795 in my hand, to see the transfer port timing/angles.
1st, exhaust port begins to open at zero degree below;
2nd, transfer port begins to open at 20 degrees in addition to the 1st. ;
3rd, transfer port begins to close at 140 degrees. So 140 - 20 = 120 degrees for transfer port angle. ;
4th, exhaust port begins to close at 160 degrees.
These new data allow me to try a reverse-calculation to the pipe I previously fabricated for 740, and it gives me results as below including its optimum velocity of rotation as 8660rpm.
Chy
chy_farm
1:10 PM
Yokohama, JAPAN
Same here but not so much fun flooring to do. I have several customers saws to fix as well. What you do takes much longer. Modern saw's are easy to fix usually.
You seem to be a carpenter my friend, if I am not too wrong that job is what I really wanted to do when I was very young, and once worked for a friend who ran a carpenter's office for some two years. It's a good reminiscing of the day, glad this friend still is a good friend of mine. Chy
p61 western
Ol Mudflap
9:10 PM
GFY
Glad to see all of this stuff in a thread over here Chy.
chy_farm
1:10 PM
Yokohama, JAPAN
Good afternoon Mike you seem to have a very nice one, Pioneer P61 I am green for that! lol. Actually we seldom see that big one here, the largest one of this series was P40 so far on a local auction here. I know it's a wonderful saw of the day!
Chy
p61 western
Ol Mudflap
9:10 PM
GFY
Chy
It's a saw that my grandpa bought brand new, and left it to me when he passed away. That was what started my addiction lol. Did you get the p40 from the auction Chy? I think that it's neat that they do show up there.
chy_farm
1:10 PM
Yokohama, JAPAN
No Mike not yet, I saw P40 at least three times on a auction here, but the seller who posted one reasonably clean did not give any reply to me to what I asked on her, so quit it lol.
chy_farm
1:10 PM
Yokohama, JAPAN
This is very intriguing Chy, we were discussing here on the forum how to do such a thing a while ago, no one here with the needed electronics background could be found. Might be you are that someone with the right technical know how. Please keep us informed on the progress of this. Also do you think an adjustable version could be possible? ---------
Good evening Steve, some years ago I found a program scripted in assembly language for the PIC, a micro controller I mentioned above, here quoted the header of this program and the link to it.
;****** Digital ignition for 2 stroke engines. SPORTDEVICES 1/9/2005
;****** Digital parts: PIC16F84
list p=16F84a
#include p16F84a.inc
radix dec
__CONFIG _WDT_OFF & _XT_OSC
(link here)
http://www.sportdevices.com/ignition/ignition16.asm
I think we have to give some modification to this, hope you like it!
As far the adjustable version for this program, not impossible but need some outer terminal to input new data, sounds better if iPhone or some other interface were available in this purpose! But I am not so skilled to accomplish this goal though, lol.
Chy
Here for the Yum Yum Sauce
11:10 PM
list p=16F84a
radix dec
(link here)
Chy
Hey Chy, so if I were to give a copy of this information to an elecromalogical type of person they should be able to make a 5 degree advance out of it? @Mastermind You see this Randy?
chy_farm
1:10 PM
Yokohama, JAPAN
Good morning Steve,
it is only my presumption that this program seems to be scripted for something like karts than saws we use. I can see at least three stages of the timing there, 'spin<5000rpm', '5000rpm< spin <15000rpm' and 'spin>15000rpm'. So I think we have to add some modification to this, like 'spin<5000rpm', '5000rpm< spin <10000rpm', '10000rpm< spin <13500rpm' and 'spin limit>14000rpm'.
It seems not a few try-and-error should be there when we go further on this.
Chy
p.s. Now going out for job, will be home in the evening.
p61 western
Ol Mudflap
9:10 PM
GFY
Good morning Steve,
Chy
Good morning Chy, have a great day.
chy_farm
1:10 PM
Yokohama, JAPAN
I wrote;
So if I want her run faster than this velocity 8660rpm with a pipe, the pipe should be like this ;
One in the upper is the previous pipe, lower a new design for 13000rpm. This tells the comparison between the two.
Chy
