Old carb ID help
67L36Driver
1:25 PM
And the missing bottom screw.
Your in luck as it is most likely available at your local hardware store.
#6-32 or thereabouts. Buy a long one and cut it to length with your wire crimpers.
backhoelover
I like tools
2:25 PM
lincolnton nc
i have several hundred of carb assmebly bolts. i keep them cause ill drop and lose one in a heat beat lol
Homemade
2:25 PM
Wisconsin
Any one try running an old saw with a broken reed? Is this a death sentence? I did have the saw running and just couldn't get it to tune all that great. Hence the carb kit.
backhoelover
I like tools
2:25 PM
lincolnton nc
Had a echo cs3000 came it had low compression. Got to looking they was no air filter pulled carb and there was a peice of wood stuck in the reed box holding it open and it burnt up the saw. It pushes your fuel out the open port.
backhoelover
I like tools
2:25 PM
lincolnton nc
I would ask some of the Guys on here they might can tell you if you can make your own reed
Homemade
2:25 PM
Wisconsin
While looking for info on the power products motor. I'm finding a good amount of parts in the vintage karting world. Maybe they'll have a reed block.
Homemade
2:25 PM
Wisconsin
Ok, I have an avenue for still shim stock. Just gotta get the reeds out and mic them. Talked to a guy at the carburetor shop.
http://www.thecarburetorshop.com/Orderinfo.htm#Telephone
And he said the carb is a H1A. And having little to no luck on that carb for some gaskets and so on. I'm hoping I can very carefully take the carb apart and soak it in the ultrasonic cleaner. I can get away without having to find a diaphragm for it.
