Odd 462 MT Problem
11:16 PM
Having an odd MT problem with a 462. Saw has been ported and Muffler Modded, but ignition timing untouched.
Saw purchased used from a dealer with 58 minutes of run time as per the computer when plugged in. Saw was nearly perfect inside and out. Dealer (whom I fully trust) ran saw stock and found zero issues-which means there weren’t any. The saw only shows the issue after 4 or 5 long cuts, so it’s possible the dealer didn’t run the saw enough for it to show.
The saw was pulled apart for a vacuum and pressure test after the issue. No leaks found. The exhaust is a bit challenging to block off on the model with its odd structure. Flywheel pulled to insure key didn’t shear-it did not.
Pump side of carb opened to insure no debris got in and plugged up screen. Looked perfect without debris.
Saw ran on 2 different mixes at 40:1. Both Efree with Motul800 and VP with Saber. Did same thing on both mixes.
The throttle linkage is not sticking. If it were, slowing chain speed by putting load on it wouldn’t change things (unless the MT could compensate for that-I guess that’s possible).
Did factory V2 reset 3X. Made no difference.
I am a bit perplexed. Any help appreciated. I tighten down the carb snugger after pulling it a part a 3rd time, but ran out of daylight for retesting. Next I plan on pulling the handle to inspect the linkage rod.
Here’s the saw. 25” 3/8 7pin in poplar test log. It’s hero wood, but I’m not gonna ruin a good oak log for testing, the poplar has no other use for me. Fast forward to 2:30 to see the issue.
DND 9000
4:16 AM
Germany
Have it checked at the dealer (complete test at the computer), especially the fuel numbers. Sometimes strange things happen. Also let the dealer check the carb/solenoid valve (pressure test). On the picture it looks like the carb is an 1142/01? Not clearly visible.
11:16 PM
Didn’t take many carb pics. Saw was purchased, used and returned for reasons besides it’s performance or function.
I will send to dealer for testing after I retry the saw.
FWIW, my other MT saws run fine on the mixes I used.
DND 9000
4:16 AM
Germany
Sometimes a fuel/oil ratio below 50:1 (like 40:1, 32:1) can give trouble, depending on the viscosity of the oil, maybe it`s a possible reason. Also which m-tronic version is this saw? See the version on the front hand guard sticker, circle in the picture. Also what is written on the control unit?
ChipsFlyin
OPE Platinum Member
11:16 PM
Pittsburgh
That little blip at 1:40 sounded weird. Was the problem maybe starting back that far? Hogging, soft cuts, hogging + pushing limits with mods. Maybe the M-tronic said What?!? I can't keep up.
Spladle160
11:16 PM
NOVA
I've heard of an identical problem on either a 261 or 241 don't remember which and don't know if it was ever solve but it was the same symptoms. Seemed to run fine then the "throttle would stick" wide open for lack of a better or more accurate description. I guess you could run it with the top cover off to ensure the throttle isn't sticking in that fun house slide linkage but it seems unlikely. how cold was it? Carb froze open?
Manofstihl661
11:16 PM
Texas
I’m not expert by annnyyyy means. But it sounds like it’s pulsing a bit unusually at idle right at the beginning. Don’t recall any of mine, mtronic or not, doing that. Maybe a fuel issue? Although it does always seem to come back to a solenoid :/
Then the next item of business is do you have enough Magnum stickers on it?
EchoRomeoCharlie
10:16 PM
South Central Wisconsin
Agree, saw seems to pulse at start up(wasn't sure if that was him messing with the throttle or not though.)
Are you sure this is a V2 saw?
Maybe try a V3 reset on it.
Spladle160
11:16 PM
NOVA
It's got to be getting extra air above idle air to run that fast right? So other than a leak the the throttle plate has to be open more than intended? new saw, stick bits, heat and expansion?
