NSP2. Cuz PA WiFi sucks
Status
Not open for further replies.
GCJenks204
"Special Buns"
7:27 AM
Winnipeg, MB
So mask all day. And if within 6 feet of another person gotta wear a face shield. Whiting Turner and Kokosing can suck a bucket full. Ass clowns.
Do you share your lift or alone? I can see a mask if 2 in a lift but a single in a lift makes no sense at all.
8:27 AM
lol he probably has been working with the same guy the whole time he has been there
we was required to wear masks if we was in the elevator with people other than our crew and when around people not in our crew
so kind of pointless now to implement that after its been a month or more at the same job
Lightning Performance
8:27 AM
East of Philly
I added power steering changed the motor to a kohler m18 magnum
Sub frame is hydraulic tank
Loader came off a John Deere 2320 that caught fire
I built the backhoe attachment a couple summers ago
I built a extra hydraulic tank where the battery was and put the battery between the rear wheel and fender so the pump didn’t cavitate on a slope
We need inside picks from the working bits under the body... slacker.
The Wayne and Dave Hour @ Wally World Headquarters
Dis is gonna be fun.
About one short and curly from gravity winning.
View attachment 246320 View attachment 246321
Go ahead and bump it... you know you want to. You better get a tall jack and hang the mfer from a few trusses, just in case.
Gravity and water always win eventually.
Is that track roller resting on the power cable wraps?
If so you get bonus points for not frying yourself during the restart.
Dream
8:27 AM
Elberton, GA
Yep. Its sitting on the conductor bar. Locked it out.
Will be rigging a chainfall to support the sketchy end, with a forklift as backup. Once we get it stable, we will rig it to the forklift and lift it back onto the rails. Then we get to see what else is fugged.
8:27 AM
If so you get bonus points for not frying yourself during the restart.[/QUOTE pictures of what the subframe ?
its 2x4 square tubing with clamps going around the back axle
then 1/4 plate welded to the subframe and bolted the the tractor frame
4 plates in the front for sub frame mount that have about 16 inches of frame on each side
the pump is ran off the original electric pto its a 5.3gallon per minute pump
as for the backhoe it is connected to the rear axle with 1/2 inch pins going through the mounts for where lift arms would be
also box frame bolted to the rear and sides of the frame
8:27 AM
and you thought youd get a nap in today
41FanForLife
8:27 AM
Don Martin's House
Alone still wear mask 100%. 2 in the lift mask and face shields. The minute I see one person not wearing one mine comes off. Gonna tell someone to scrub out their dick hole with a wire brush real soon
41FanForLife
8:27 AM
Don Martin's House
Been here 3 months. And it's a problem today. Let's invent some more things to slow me down even more
Status
