- 9:21 AM
- Feb 5, 2016
- grafton wv
Damn slackers
what meat did you useWell, I have to report that the Taco Bell kit from the grocery store is a complete and utter failure. I kept waiting and waiting... nothing. Even my daily constitution was normal. Now, I do realize I didn't have and E-coli laden lettuce, but there's something different going on here, I think it's just one of the regular taco kits relabeled.
50/50 grind is what *s-wordholes use
Not sure who you're referring to. It's already second break time here. Halfway through a normal day.Damn slackers
theres why it wasnt greasy enough90/10 Venison/Bacon
everyoneNot sure who you're referring to. It's already second break time here. Halfway through a normal day.
kinda looks like @Dream
Doing good. Don't want to say it too loud, but I think I tracked down the machine I've been looking for. Still in a crate. Hopefully it's not full of gravy, cheese curds, and farts from @Canadian farm boy and @GCJenks204theres why it wasnt greasy enough
everyone
hows you
Some have it. Can't recall seeing one on a factory 350 though. Which model carb?Morning meat puppets.
Carb question, Walbro HDA.
There should be a black spacer where I'm pointing, correct?
I have 3 carbs here and only 1 without it. And it is/was on a 350 that supposedly ran.
159s are stock for a 350. A 199 will usually work but that's a lot of carb for that saw. I had one with a plastic choke loop that the throttle linkage bound up on any small chassis 3xx but they usually work. The plastic spacer is Husky's attempt at a compensating carb. All 199s on 357s and 359s have them. You can eliminate it with a hole drilled in the cover. Watch your gasket orifices too if you do that.The one missing the spacer is a 159.
Then there was a 199 in the box with it.
And a 199A in a box O'357 I picked up as well.
The other is on a friends stepdads 359, which is pissing gas out from various places and wont run right ever since he spent all last Saturday noodling with it...and judging by the lack of a chain, blue bar rails and wood powder on the saw, it got a bit warm...
159 isn't missing anything, the 199 is for a 359 has the accelerator pump in it, which I'm not a big fan of. If you replace go with a 198.
hiccups?159 isn't missing anything, the 199 is for a 359 has the accelerator pump in it, which I'm not a big fan of. If you replace go with a 198.
