leadfarmer
Hot Rod !!!
- 11:12 PM
- Dec 28, 2015
- S Central PA
Sup with the 125?Dats bout like mine[emoji16]
I didn't go look at it this evening. I'm still trying to get the brakes figure it out on my dump truck . it's being a pain in the ass.Sup with the 125?
Rear abs messing with you?I didn't go look at it this evening. I'm still trying to get the brakes figure it out on my dump truck . it's being a pain in the ass.
Something is , I just spent an hour on Google and it keeps talkin about that. I put new front calipers rear drums and shoes and I still don't have no farkin pedal. Master cylinder looks like it's fairly new I was going to change out next time I found this crap. I think I've went through a half gallon of brake fluid so far. This may be the reason I'm a Chevy guy. [emoji16]Rear abs messing with you?
Lol....Simms down mister [emoji36]Just have @dall bail out the back and hang on the bumper.
Should slow down eventually.
Yes I have shoes dragging nicely on the drum I now have decent emergency brake and yes it is a Furd. A 96 f350Shoes adjusted good and snug?
Out of adjustment shoes can cause a mushy pedal.
It's a Furd, right?
The boosters have been known to go bad. You may need to bleed the abs module also. It's right below the firewall on the driver's side. Some folks just delete the abs module also.Something is , I just spent an hour on Google and it keeps talkin about that. I put new front calipers rear drums and shoes and I still don't have no farkin pedal. Master cylinder looks like it's fairly new I was going to change out next time I found this crap. I think I've went through a half gallon of brake fluid so far. This may be the reason I'm a Chevy guy. [emoji16]
thats what you get for buying a turdShoes adjusted good and snug?
It's a Furd, right?
Gahey....
I watched some YouTube guy take the end off and pull the spring out so he could Bleed It . It looks like it only goes to the rear brakes so yes I would love to delete itThe boosters have been known to go bad. You may need to bleed the abs module also. It's right below the firewall on the driver's side. Some folks just delete the abs module also.
No Thir[emoji6]Is that a problem?
Only if your one of the guys in the picture I posted last night lol.Is that a problem?
Delete that bish.I watched some YouTube guy take the end off and pull the spring out so he could Bleed It . It looks like it only goes to the rear brakes so yes I would love to delete it
do you lift your pinky finger as you drink?Cheap single cup coffee maker here. I drink tea mostly....suck it bishes.
Sometimes.do you lift your pinky finger as you drink?
