NSP2. Cuz PA WiFi sucks
Status
Not open for further replies.
AlfA01
7:56 PM
Evia, Greece
It was 70 here today....too bad I spent it in a crawl space and then installing a water heater in a tiny closet. Any of you fellas got hard water?
These folks have got a bathroom that is just trickling hot water. It has great psi leaving the water heater. Pipes are in cement walls.
beaglebriar
The Peanut Gallery
12:56 PM
Warren Center, PA
Yep check where the supply lines attach to the hard line/valve. Mine will get a build up of mineral flakes right there. Then pull the screens and soak in vinegar (which you probably have done already).
Lightning Performance
12:56 PM
East of Philly
I recommend a steel work head with teeth on the snake to eat up those hard deposits and a Vitamin C filter cartridge on the main inlet to stop that build-up of minerals.
Don't have those problems here. Some lime and iron is about all we have in the sand here. Not too bad for me being on the end of a town line of 100 residential homes plus businesses. In the pines is about the worse with iron on flat land here and direct wells.
Status
