NSP2. Cuz PA WiFi sucks
Status
Not open for further replies.
Bilge Rat
11:07 AM
savannah georgia
Did a timing belt break?
A weedeater and blower followed me home.
Both have carb issues.
The Stihl weedeater is 15 yrs. old with just a yearly airfilter cleaning.
It is in great shape.
Stihl 430 blower has duct tape on the harness.
Dirty but it runs
redline4
I'm huge in Japan
10:07 AM
Rosholt Wisconsin
No belt, just saw the ID of the motor.
What is killing lifters?
GM is having us replace what it known as the valve lifter oil manifold any time we get an active fuel management lifter failure.
It sits in the valley and has solenoids which dierct oil to the lifters to "unlatch" them during cylinder shutdown.
It's thought that slight internal oil leaks are causing the latches to fail.
I personally think its asking 1 thing to do too much. Ive seen the lifters blown apart into 3 pieces, I've seen them stuck in their "on" positions, and I've seen them collapsed.
Sometimes it pretzels a pushrod, sometimes not.
These engines have them on 4 cylinders, #1, #4, #6 & #7.
The new gen engines in the 2020's have them on all cylinders and can effectively shut down up to 6 cylinders if everything is met...yes, it will run down the road as a V-2.
Canadian farm boy
“Normal” people scare me.
11:07 AM
Ontario, Canada
DOD delete ftw :D
redline4
I'm huge in Japan
10:07 AM
Rosholt Wisconsin
DOD delete ftw :D
For what it's worth, I have never heard of one failing in a truck that simply had a tune to turn it off and left the active lifters still in there.
The constant latching and unlatching by oil pressure is what must be killing them.
full chizel
¯\_(ツ)_/¯
11:07 AM
USofA
Canadian farm boy
11:07 AM
Ontario, Canada
The constant latching and unlatching by oil pressure is what must be killing t by em.
Like you said, “one component doing to many things”.
Member
10:07 AM
Run the engine on 2,3,5 and 8. :confused:
Canadian farm boy
11:07 AM
Ontario, Canada
I also installed a catch can on mine. You’d be amazed how much slop that thing catches.
redline4
I'm huge in Japan
10:07 AM
Rosholt Wisconsin
Exactly lol
Being at the dealer and constantly working on the new stuff, there's times I view the 6.0 in my 2006 as old school.
Iron block, aluminum heads, no variable timing or active fuel management.
Those engines run damn near forever..
Canadian farm boy
11:07 AM
Ontario, Canada
Are you seeing any patterns with the failed lifters? Higher Mileage or cold weather or anything like that?
redline4
I'm huge in Japan
10:07 AM
Rosholt Wisconsin
Nope..
Todays victims had 125,000 miles on the truck, 60,000 miles on the Escalade.
I've replaced them under the 36,000 mile bumper to bumper warranty too.
I have noticed that any time I have an intake off, I've noticed that the lifter manifold bolts are backed out and loose. Usually can remove with my fingers. So, loose bolts, oil from block, into manifold and back to block to lifters, yeah, there's your oil leakage issue..
Bilge Rat
11:07 AM
savannah georgia
350, all cast iron, 4 bolt mains, 1 wire HEI, Q jets, or Holley done properly.
The lastest i go is 1999 5.7.
p61 western
Ol Mudflap
8:07 AM
GFY
Yep I'm not convinced that the new stuff is better honestly.
Status
