NSP2. Cuz PA WiFi sucks
Status
Not open for further replies.
10:37 PM
Went to the local amish restaurant today...
Too bad Dallas dont sea this...[emoji41]
He sees all lol.
Lightning Performance
11:37 PM
East of Philly
Evening.
What are you using to set the posts?
(we’d kill for a 12” frost line. We average 4’ and have been 10’ on a bad winter. Underground plumbing here has to be below 6.
Post gets set with stone and sand. No concrete, no need.
It has three coats of 10-30 :)
Good afternoon fellas. Got the 350 home. 4 bolt main was a nice surprise. Everything looks great in the bottom end.View attachment 211467
Check every bearing with plastigauge or disassemble the bottom end and do it right! Never trust what you got from someone else.
Good base for a 383 stroker build;)
Negative. Four bolts crack at three and four main bearing web from the exsposed threads. A two bolt with splayed caps and line bored should be used on all 383's. I've seen too many cracked motors built on four bolts in heavy street cars. I cracked two in my 78' four speed four by four 355 pu. I run with a top loader and a NP205 2.16LR
Yep after he has some driving experience under his belt. I had a nasty 383 in my old 64 El Camino. It was actually a bit much for daily driving. Less cam and carb would have helped, but the compression was to high for pump gas.
Swap in dished pistons.
Damn she is pretty but too young.
Getting dragged to a Christmas party at Tamara’s boss’s house. At least it will all be top shelf because he’s a pretentious prick...
Drink all his best Crown Royal
Status
