R2D
- 9:51 PM
- Dec 24, 2015
- Northeast il
Time to go fix a cable line.
Well I am short.......No, the mental midgets and wanna be Canadians
Plus me, the smartest man you'll ever meet
Question for those of you that run saws way more than I..
Is it normal to have to knock a link or two out of a chain as it wears out? I was touching up a loop of RS this morning and while cleaning out around the clutch on my 372 I noticed that I am nearing the end of the adjuster slot in the bar. Oregon bar.. 84DL. Now I often go 2-3 tanks with out a touch up.. I'm pretty particular on my chains and filing a rocked out chain or 10 will make a man watch where that tip goes! I'm thinking if it was getting touched up every tank or other tank... the cutters would disappear faster and not be an issue. Oiler is maxed out and the bar hole opened up.. I keep the bars lubed. Just looking for others thoughts experiences.
Thought you were just surrounded by midgets? I have no idea where I fit in.Well, im not a wanna be Canadian so i guess i know where i fit in. [emoji35]
Have you been using the same bar? Or is a different one?Question for those of you that run saws way more than I..
Have you been keeping the rakers filed down?Question for those of you that run saws way more than I..
I see.
Is this thread becoming pretty active?
I've been too busy to check in much.
Are you running them too tight?Question for those of you that run saws way more than I..
I don't believe you.I forget what that means.
It is one of two loops of Stihl chain i have for this bar.Have you been keeping the rakers filed down?
(Buy stihl chain)
Dont think so...can pick a driver out of the groove but it has no sag.Are you running them too tight?
Same bar...Have you been using the same bar? Or is a different one?
I know Dad has gotten a few Husky bars for his 550 and he had to knock out a link after awhile. He now has a Oregon bar on it and them chains are damn near to short.
Is it just on one chain?I dunno...if it gets to that point ill knock a link..just wondering. Sounds a bit un-normal.
