czar800
- 10:54 PM
- Jan 14, 2016
- Ellwood City
Anyone know what the transmission need to operate with no Computer?
This one only had a "Blazor" chain. The other 33% can only be achieved with a "Razor" chainWhat no 40% what's up with that Kevin?
427 and th400 tranny gtg.I've dreamed about a 427 in a pickup for years.
turbo 350 and turbo 400 doesnt use computer
Just a seat of the pants.Should be able to drop a 4.8,5.3 in if no budget friendly 6.0 available..
Just a flex plate spacer, and ecm reflash should be all that's required...
I know there's a lot of love here for an old school carbureted sbc, and I'm also a fan, but when was the last time you guys saw one that went 3-400k miles without a rebuild? If the oil is changed every 5k miles on these vortec (or whatever they're called since 98 or 99) they'll outlast 2 or 3 bodies. Imo, they'll damn near go forever with simple maintenance. 350's needed a cam every 60kShould be able to drop a 4.8,5.3 in if no budget friendly 6.0 available..
Full manual valve body, or a stand alone transmission controller round 600$
Just say no.
It will likely cost you more to convert that truck to sbc/BBC than it would to swap in a reman 6.0.
Now your talking m22 rock crusher.427 4 speed!
It's fun to think about....
Th 400 will bolt to your t case with the correct length output.
The big block and small block will require new motor mounts. If you go big block you could possibly use the 8.1 motor mounts. But may have to fabricate some.
I know for a fact the radiator will be struggling to keep up.
Likely need new driveshafts made.
Tall deck big block oil pan will need swapped out.
The fuel pump will need to be regulated down at the engine.
Wireing could be a hassle, as the ls is distributer less..
All new exhaust.
The list goes on
Likely get a new gm 6.0 replacement cheaper....
Just buy a Ford and be done with it.Th 400 will bolt to your t case with the correct length output.
All new exhaust.
The list goes on
Sorry. I know it was fun, but any sort of current efi is better than a quadrajunk.Aren't you just a big rain cloud of reality...![]()
lmfaoI was just digging around for sawzall blades to cut the hole for the stick...![]()
