czar800
- 11:50 AM
- Jan 14, 2016
- Ellwood City
Good afternoon, not so pros!
Any pics of the finished product?I finally got the wood splitter finished up this morning. You have a outstanding new year my friend
Coming right upAny pics of the finished product?
Thanks for the pics,I got some good idea's from this.Got the hydraulic lines made longer was the last part. The adjustable leg is also missing in pic. It's made and layin at the shop![]()
Mmmmmmhhhhhhhhh how convenient buddy.Ok i gotta go back to work tues
If id a known i would have lol
That seal shouldn't see any pressure. Is there a breather somewhere on the casing that might be plugged??Help me out smart fellers. This is the second time Ive pulled this plow pump because the seal has pushed out of the race. The seal looks fine. Is it just not enough tension in the race or is something else going on? Was thinking some loctite retainer to lock it in there. @DSS, Chris, Kevin said you may know?View attachment 47473View attachment 47474
Is that line at the bottom a case drain or where does it go? It's possible the seal is just loose in the bore but it doesn't happen very often. If that's a case drain back to the tank and it's restricted in any way, or not big enough to start with, it'll build up pressure and push the seal outHelp me out smart fellers. This is the second time Ive pulled this plow pump because the seal has pushed out of the race. The seal looks fine. Is it just not enough tension in the race or is something else going on? Was thinking some loctite retainer to lock it in there. @DSS, Chris, Kevin said you may know?View attachment 47473View attachment 47474
Yes, the shaft in the aluminum housing is the pump gear. The motor which is the yellow part in the pic spins the shaft.Does that shaft spin do it have a o ring on it letting oil past and pushing seal out
