Status
Not open for further replies.
paragonbuilder
4:21 AM
Norwich, CT
Genius
First member of ASlite to receive a infraction
4:21 AM
Uncle Willys basement
I think that's Virginia Creeper with the ragged edges. Poison ivy is usually smooth edges. I think. And it doesn't grow on the ground much. Is the vine hairy?
I tripped and fell in it while getting wood. I didn't move the leaves around to look at the stem.
I do know that around here it grows on the ground and as a vine up trees and buildings
paragonbuilder
4:21 AM
Norwich, CT
I didn't know it could grow on the ground. I've only seen it on trees and stonewalls around here. Maybe that's why I get it so often [emoji849]
exSW
'Cause Thomas is a poopyhead
4:21 AM
United States
Check the oil regularly,stick a little piece of black electrical over the check engine light and drive it. When it blows(if it blows) there are lots of them out there. Lots. I predict you'll need a frame before you need an engine.
exSW
4:21 AM
United States
I'm no mechanic, but couldn't broken rings cause positive crankcase pressure resulting in a high oil pressure reading.
Does he have positive crankcase pressure? Try popping the oil fill off while it's warmed up and running. I'd change the oil pressure sending unit.
Status
